PR message
"Our strength is precision pin/shaft machining using our core technology of sub-micron precision grinding utilizing in-house developed facilities. We achieve high-quality using our integrated manufacturing system and facilities for machining, grinding, and heat treatment. We can offer optimal proposals corresponding to customers' requests, from prototypes to mass production.
The unit of the world's smallest grinding slip screw
フェルールの融着機用部品で、消耗品でもあります。ポイントは、先頭形状で、R0.05mm+0-0.03mmの精度が求められています。類似用途で、シリコン、チタンでも製作可能です。
High precision( Mass production / Mechanical processing ) |
Company name | TNK SANWA PRECISION CO.,LTD | Website URL | |
Street address |
Tsukuba-shi, Ibaraki Japan
[See map] |
Person in charge | Masahiro Tanaka |
Telephone number | +81-29-866-0811 | Fax number | +81-29-866-1100 |
Capital | 100,000,000 JPY | Employees | 210 |
Annual sales | Unregister | EMIDAS Member Number | 81997 |
Type of manufacturing | Home electrical appliances / Telecommunication equipment / Transportation equipment | ||
Main 3 products |
Large | Medium | Small |
Mass production | Mechanical processing | Stainless Nickel alloy High precision |
Surface treatment | Barrel polishing | Barrel finishing (rotation) Barrel finishing (centrifugal) |
