Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Welding( Development and production of prototype/Small-scale production / Prototype processing ) |
Stainless steel( Mass production / Metal press ) |
TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Machine tool manufacturing( Product manufacturing / Production property ) |
Semiconductor manufacturing equipment manufacturing( Product manufacturing / Production property ) |
Company name | Yokohama System Co., Ltd. | Website URL | https://yokohama-system.co.jp/ |
Street address |
Yokohama-shi Kanagawa Japan
[See map] |
Person in charge | Hiroshi Haga |
Telephone number | +81-45-534-0071 | Fax number | +81-45-534-0072 |
Capital | 10,000,000 JPY | Employees | 25 |
Annual sales | 360,000,000 JPY | EMIDAS Member Number | 81816 |
Type of manufacturing | Machine tools / Industrial machinery / Transportation equipment | ||
Main 3 products |
PR message
We are a manufacturing company that deliver added value.
Mainly manufacturing sheet metal and cans, we handle from small to large products.
With the motto of high added value and quick delivery, we have the technical capabilities and equipment to meet our customers requests.
By laser processing and press processing, we perform design, processing until assembling of industrial machinery (frames/ covers/components), train vehicle parts, power distribution/control panels, industrial equipment, shipbuilding parts, construction hardware, plants, exhibits, etc.
Most recent update:2023-06-14
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Iron Stainless steel Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Titanium |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Laser marking Microfabrication (laser machining ) Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Glass laser machining Precision cutting |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding YAG laser machining Fiber welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Chassis prototype manufacturing |
Mass production | Metal press | Bending Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Corson alloy Beryllium copper Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) |
Parts manufacturing | Other parts | Sign board manufacturing |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Carrier machine manufacturing Measurement/testing devices manufacturing Optical products manufacturing Freezer equipment manufacturing Vacuum equipment manufacturing Food industry machinery manufacturing Chemical industry machinery and equipment manufacturing Industrial robot manufacturing Information equipment manufacturing Monitoring device manufacturing Environmental equipment manufacturing Semiconductor manufacturing equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing Marine vessel equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing Construction and civil engineering material manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
Product manufacturing | Food industry machinery manufacturing | Food manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing Transportation equipment manufacturing Telecommunication equipment manufacturing |
