Large current board( Parts manufacturing / Electric board and electronic part ) |
Injection molding die( Designing / Mold designing ) |
Plastic protocol machining( Development and production of prototype/Small-scale production / Prototype processing ) |
Insert molding die( Die manufacturing / Plastic mold ) |
PPS (polyphenylene sulfide)( Mass production / Plastic ) |
PBT (polybutylene terephthalate)( Mass production / Plastic ) |
Copper( Surface treatment / Plating/Chemical conversion treatment ) |
Metal press( Assembly/Inspection / Inspection ) |
Part processing( Die manufacturing / Press die ) |
Brass( Mass production / Metal press ) |
Company name | Kojin Co., Ltd. | Website URL | |
Street address |
Nakaniikawa-gun, Toyama Toyama Japan
[See map] |
Person in charge | Hiroshi Ikeda |
Telephone number | +81-76-473-3251 | Fax number | +81-76-473-2692 |
Capital | 83,500,000 JPY | Employees | 158 |
Annual sales | 4,200,000,000 JPY | EMIDAS Member Number | 79151 |
Type of manufacturing | Industrial machinery / Electronic parts / Electrical component for transportation equipment | ||
Main 3 products |
Primary clients |
PR message
Our company perform production activity specialized in vertical insert molding in resin ejection molding.
We have an order from the widely industry such as a car, industry, and public welfare, and deal with from trial manufacture to a mass production.
Our company possesses the vertical molding machines for insert molding; from the small size of 30t to the large size od 260t, which are equipped 56 in Japan and 12 in Indonesia.
We manufacture goods in a continuous process from the insert part with the precision press to molding, finish, inspection.
Please feel free to contact us at first
Most recent update:2024-12-27
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Progressive die designing (auto) General metal press die |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Bending die Blanking die Progressive die Below 60 t 60 - 300 t |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining Injection molding die Insert molding die Outsert molding die Below 60 t 60 - 300 t Electrode manufacturing |
Mass production | Metal press | Bending Blanking Copper Brass Phosphor bronze Thickness Single press (below 80 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Plastic | Insert molding Outsert molding Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) LCP (liquid crystal polymer) Elastomer Below 60 t 60 - 300 t Injection molding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Electroless nickel (barrel) Copper Brass |
Assembly/Inspection | Assembly | Precision equipment assembly |
Assembly/Inspection | Inspection | Metal press Plastic |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
Parts manufacturing | Electric board and electronic part | Large current board |
