We specialize in precision machining of hydraulic pumps and automotive parts, as well as thin-walled, high-precision lathe machining. We also created seismic base isolation devices and wind power producing blades in response to diverse problems. We provide our customers with trustworthy technologies.
NC turning machining( Mass production / Mechanical processing ) |
Machining( Mass production / Mechanical processing ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Machining (horizontal)( Development and production of prototype/Small-scale production / NC machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Press forging( Mass production / Forging ) |
Plane grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Aluminum( Mass production / Forging ) |
Iron( Mass production / Metal press ) |
Casting( Development and production of prototype/Small-scale production / Machining ) |
Company name | Sawakawa Tanzo Kogyo Co., Ltd | Website URL | https://www.sawakawa.co.jp/ |
Street address |
Takaoka-shi Toyama Japan
[See map] |
Person in charge | 澤川 幸利 |
Telephone number | +81-766-63-1263 | Fax number | Log in to display |
Capital | 10,000,000 JPY | Employees | 42 |
Annual sales | EMIDAS Member Number | 79101 | |
Type of manufacturing | Machine tools / Industrial machinery | ||
Main 3 products |
PR message
We primarily process and manufacture machinery-related components, such as precise parts for hydraulic pumps and hydraulic motors, bearing rings, and vehicle parts.
Our company has expertise with medium and large-sized products ranging from 50 to 700 mm, thin walls, high precision lathe processing, and burnishing processing. We solve difficulties by developing concepts that combine creativity and technology to fulfill the demands of our customers. Please leave any inquiries about thin-walled high-precision lathe or burnishing processes to us.
We provide solid assistance to our costumers through dependable technology and innovation.
~ Moving forward and continue to take on challenges ~
We have greatly expanded our manufacturing scope by our reliable forging technology.
For example, in 2002, we began manufacturing a seismic isolation safety device that reduces shaking during an earthquake at the request of Nachi-Fujikoshi Corp. We cut the house's pillars horizontally and placed metal balls between them, allowing the structure works to absorb shaking during an earthquake.
Furthermore, we got an inquiry from an aluminum product manufacturing company concerning the possibilities of producing wind turbine blades for wind power production utilizing an integrated press with magnesium as the material. we created a small prototype by changing the metal material and mold and were able to build a footing for practical use.
Most recent update:2025-04-21
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Molybdenum alloy Lathe machining (resin) Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing |
Development and production of prototype/Small-scale production | Blank cutting | Shearing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding |
Die manufacturing | Press die | Drawing die Blanking die Single press die |
Die manufacturing | Forging die | Designing Manufacturing Cold forging die Press forging die Warm forging die |
Mass production | Metal press | Drawing Iron Aluminum Copper Titanium Thickness Thickness Thickness Single press (80 - 200 t) Single press (200 - 500 t) |
Mass production | Mechanical processing | Machining NC turning machining Iron Stainless Aluminum alloy Copper alloy Casting Titanium |
Mass production | Forging | Cold forging Press forging Iron Aluminum Brass Others Below 500 g Warm forging |
Parts manufacturing | Machinery part | Valve manufacturing Bearing manufacturing Shaft and roller manufacturing |
