NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Robot welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Industrial machinery designing( Designing / Industrial equipment designing ) |
Energy-saving machinery designing( Designing / Industrial equipment designing ) |
Industrial machinery assembly( Assembly/Inspection / Assembly ) |
Arc welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Keyway milling( Development and production of prototype/Small-scale production / Machining ) |
Carrier machine designing( Designing / Industrial equipment designing ) |
Company name | Genesis Maruyama Kikai Co.,Ltd. | Website URL | http://www.maruyamakikai.co.jp/ |
Street address |
Takasaki City Gunma Japan
[See map] |
Person in charge | hidekazu taniguchi |
Telephone number | +81-27-361-6631 | Fax number | +81-27-362-4102 |
Capital | 20,000,000 JPY | Employees | 28 |
Annual sales | 500,000,000 JPY | EMIDAS Member Number | 79074 |
Type of manufacturing | Industrial machinery / Construction material / Transportation equipment | ||
Main 3 products |
PR message
We strive to become the organization with “positive thought, friendly atmosphere, and powerfulness of the monolith”. There are two kinds of people when it comes to the process of accomplishment. Some will instantly abandon and seek for the excuse while others contemplate for the possibility. It is wise to belong in the latter group with the positive mind set and inspiration. If the result ends with failure, simply challenge again.
We work together in this company linked by fate. Since we spend most of our life time in the organized company, keeping a good relationship with others is ideal as family relationship. Built on top of such idea, we work on constructing a cheerful working atmosphere where all employees can have their own thoughts and discuss seriously.
If two equivalent forces face opposite direction, they both can't step forward. In addition, if many equivalent forces face in scattered directions, it is easy to lose the true path. Our goal is to become the organization that all employees seek for the future as an unite and grow as an unit.
Most recent update:2025-04-14
Large | Medium | Small |
Designing | Industrial equipment designing | Carrier machine designing Industrial machinery designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Sintered metal Keyway milling Shaper machining Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Sheet metal protocol manufacturing Coating Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Shearing (longer than 121.2 m) Thin plate (below 6 mm) Stainless steel |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding Cylindrical grinding Jig grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding Other bonding methods |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Packaging machinery manufacturing Hydraulic pressure equipment manufacturing |
