Progressive press (80 - 200 t)( Mass production / Metal press ) |
Progressive die designing (auto)( Designing / Mold designing ) |
Progressive die designing (light electrical)( Designing / Mold designing ) |
Drawing metal press die designing( Designing / Mold designing ) |
General metal press die( Designing / Mold designing ) |
Single press (80 - 200 t)( Mass production / Metal press ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Tapping( Development and production of prototype/Small-scale production / Machining ) |
TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Robot welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Company name | Zaou Seisakusho Co.,Ltd | Website URL | https://www.zao-press.jp/ |
Street address |
Kaminoyama-shi Yamagata Japan
[See map] |
Person in charge | 高橋 辰男 |
Telephone number | +81-23-672-2237 | Fax number | +81-23-672-2418 |
Capital | 45,000,000 JPY | Employees | 80 |
Annual sales | Unregister | EMIDAS Member Number | 78410 |
Type of manufacturing | Office automation equipment / Transportation equipment / Medical equipment | ||
Main 3 products |
PR message
☆ Please leave precision press processing, precision sheet metal processing, press mold design/production, and press mold parts production, to Zaou Seisakusho Co., Ltd.☆
≪About Zaou Seisakusho Co., Ltd.≫
We specialize in precision sheet metal processing by laser processing and press processing from a minimum of 35 tons to a maximum capacity of 300 tons.
The most important aspect for satisfying our clients' QCD is that we handle everything in-house, from mold manufacture to press work, as a one-stop shop. We provide extensive post-press services such as caulking, tapping, spotting, welding, and assembly.
≪The reason we were chosen≫
We design and manufacture the mold depending on the product you desire, allowing us to make precise modifications based on the prototype.
≪Manufacture of moldless products≫
It is possible to support moldless items created by laser irradiation at a reasonable cost if simply cutting (blank) is required.
≪Mold sales≫
We also manufacture and sell molds only.
Please contact us if you do not have press mold production equipment.
In addition to mold design requirements, we can manufacture molds after obtaining mold design drawings.
≪Prompt response to prototypes≫
We can manufacture a minimum of one prototype in as short as one week, depending on the shape you require.
Please contact us if you prioritize speed over anything else.
≪Materials we can handle≫
Iron…SPCC, SECC, etc.
Stainless steel…SUS304, SUS430, etc.
Aluminum…A1100P, A5052P, etc.
Copper alloy...C1100, C2680, C5210, C7521, etc.
We may also can handle other materials, so please do not hesitate to contact us.
We are currently working on improving our sales support.
◇Contact us◇
225 Osawa Sengoku, Kaminoyama-shi, Yamagata 999-3122
TEL: +8123-672-2237 FAX: +8123-672-2418
E-mail: y-suzuki@zao-press.co.jp
Please contact Sales Department (PIC:Suzuki)
Most recent update:2025-04-10
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die 3D modeling (press) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping Iron Stainless steel Aluminum alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Sheet metal protocol manufacturing Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Laser processing (longer than 121.2 m) Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Fiber laser processing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding Projection welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing prototype mold |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling Drawing die Bending die Blanking die Shaving die Progressive die Single press die Press robot die 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Shaving Iron Stainless steel Aluminum Copper Plated steel plate Thickness Combined press-joining Press robot (80 -200 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
