5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
Vacuum quenching( Surface treatment / Heat treatment ) |
Simultaneous 5-axis machining( Development and production of prototype/Small-scale production / Machining ) |
Data creation (3D scan)( Designing / Data creation (3D scan) ) |
Fused Deposition Molding (FDM)( Development and production of prototype/Small-scale production / Prototype processing ) |
3D printer( Designing / Data creation (3D scan) ) |
Sub-zero treatment( Surface treatment / Heat treatment ) |
Company name | Yamaichi Special Steel Co., Ltd. | Website URL | |
Street address |
Nagoya, Aichi Japan
[See map] |
Person in charge | Yasuharu Ohba |
Telephone number | +81-53-425-7821 | Fax number | +81-53-425-7823 |
Capital | 80,000,000 JPY | Employees | 221 |
Annual sales | 16,000,000,000 JPY | EMIDAS Member Number | 77348 |
Type of manufacturing | Jigs and tools / Machine tools / Transportation equipment | ||
Main 3 products |
PR message
We, as a special sales agent of materials from Hitachi Metals, Ltd., supply special steel materials to dies/molds and parts molding manufacturers. In 2016, Prismadd, a Franch company and we established Prismadd JAPAN, the first in Japan to enable the End-to-end system of Additive Manufacturing. We have currently expanded globally to Thailand, Vietnam, Singapore, and Malaysia and supply our products to the automobile, defense, and medical industries.
Most recent update:2025-02-25
Large | Medium | Small |
Designing | Data creation (3D scan) | 3D printer Data creation (3D scan) |
Material | Steel component distribution | Heavy plate Stainless steel Stainless steel spring Stainless steel pipe Hot-rolled steel plate Cold-rolled steel plate Tool steel Spring steel Free-machining steel Other steel plates and straps Flat steel plate Steel (round) bar Wires Seamless steel pipe Welded steel pipe Rectangular steel pipe Drawn steel pipe Steel castings rolling |
Material | Specialized material distribution | Phosphor bronze Molybdenum alloy Nickel chromium alloy Ceramic material rolling |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Copper and brass products Titanium Pipe material Magnesium Coils Others rolling Aluminum extrusions |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Rolling Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Sintered metal Keyway milling Automatic lathe Router machining Simultaneous 5-axis machining Casting Handles microfabrication Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Profile grinding Jig boring Jig grinding Internal grinding Centerless grinding Gear grinding NC internal grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Photoforming Fused Deposition Molding (FDM) Powder sintering Sheet lamination |
Development and production of prototype/Small-scale production | Casting | Low pressure casting cast iron Ductile cast iron Cast steel |
Die manufacturing | Press die | Manufacturing Part processing Plate machining Die set machining 3D modeling Drawing die Bending die Blanking die Fine blanking die Shaving die Progressive die Transfer press die Single press die Below 60 t 60 - 300 t Over 300 t |
Die manufacturing | Plastic mold | Manufacturing Part processing Plate machining 3D modeling Below 60 t 60 - 300 t |
Die manufacturing | Spring mold | Spring die part processing |
Die manufacturing | Forging die | Forging die part processing |
Die manufacturing | Casting die | Die-casting part processing Die-casting die Lost-wax casting die |
Surface treatment | Coating | Air-spray coating Heat insulation coating Heat-resistant coating Metal coating |
Surface treatment | Printing and others | Laser engraving |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Air quenching Vacuum quenching Flame quenching Sub-zero treatment |
Product manufacturing | Household commodity | Outdoor leisure product manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
