Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Projection welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Prototype/Small-lot molding( Development and production of prototype/Small-scale production / Prototype processing ) |
Auto parts assembly( Assembly/Inspection / Assembly ) |
Pipe machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Injection molding die( Die manufacturing / Plastic mold ) |
General metal press die( Designing / Mold designing ) |
Simple mold, prototype mold( Development and production of prototype/Small-scale production / Prototype processing ) |
Insert molding die( Die manufacturing / Plastic mold ) |
Company name | Asano Co.,Ltd. | Website URL | http://www.asano-japan.com/eng.html |
Street address |
Isesaki-shi Gunma Japan
[See map] |
Person in charge | Hagiwara Hideyuki |
Telephone number | +81-270-75-1700 | Fax number | +81-270-75-1600 |
Capital | 90,000,000 JPY | Employees | 287 |
Annual sales | EMIDAS Member Number | 77273 | |
Type of manufacturing | Jigs and tools / Industrial machinery / Transportation equipment | ||
Main 3 products |
PR message
Product development supporting and production preparation supporting
Business range: trial sheet metal parts production (trial stamping dies – trial sheet metal parts production – assembly), trial pipe processing, machine tool processing, fixture design and production, mass-produced sheet metal parts production, mass-produced stamping die production, injection precision mould production, mould design, CAD design, CAE analysis, simulation, shape measurement, reverse engineering, development of other products and supporting services in production preparation.
◆Head office, Gunma factory
Production of prototype sheet metal parts(metal mold to product and assembly);
machining, design and production of jigs, 3-D CAD design, simulation, shape measurement, reverse engineering, welding, assembly, pipe processing, hand-work, Design and production of press metal molds and jigs for mass production.
◆Shizuoka factory
Trial sheet metal parts production (moulds– products and assembly), mass-produced parts production, mass-produced mould production and shape measurement.
Most recent update:2025-02-28
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die 3D modeling (plastic) NC data creation (press) |
Designing | Jig and tool designing | General jig designing Welding jig designing |
Designing | Test | Specimen processing Destructive test |
Designing | Simulation | 3D modeling Press Welding Structure |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Molybdenum alloy Machining (resin) Sintered metal Keyway milling Automatic lathe Milling (resin) Lathe machining (resin) Handles microfabrication Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining NC vertical lathe Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Sheet metal protocol manufacturing Pipe bending 3D pipe machining Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Laser marking Thin plate (below 6 mm) Stainless steel Copper/Aluminum 3D laser machining Fiber laser processing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Cylindrical grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Seam welding Arc welding Robot welding Brazing Brazing Stud welding Projection welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Welding Bending Small-size prototype manufacturing Prototype/Small-lot molding Small-lot/Injection molding prototype mold |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining NC data creation 3D modeling Drawing die Bending die Blanking die Progressive die Transfer press die Single press die Press robot die Below 60 t 60 - 300 t |
Die manufacturing | Plastic mold | Designing Manufacturing Injection molding die Insert molding die Below 60 t 60 - 300 t Thin wall injection molding die |
Die manufacturing | Rubber mold | Rubber mold part processing and other auto parts |
Die manufacturing | Casting die | Manufacturing NC data creation Sand casting die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Plated steel plate Thickness Warm forming press Transfer press (80 - 200 t) Press robot (80 -200 t) Single press (below 80 t) Single press (80 - 200 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Wire machining Electrical discharge machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy |
Mass production | Plastic | Insert molding PMMA (polymethyl methacrylate) PPS (polyphenylene sulfide) Injection molding Dual molding CFRP (carbon fiber reinforced plastic) |
Mass production | Casting | Sand casting Zinc alloy |
Mass production | Grinding processing | Cylindrical grinding |
Mass production | Sheet-metal processing | Pipe processing Sheet metal prototype manufacturing Pipe bender processing Bending process |
Mass production | Blank cutting | 3D laser |
Mass production | Welding / welding | Spot welding Robot welding fixing with wax |
Assembly/Inspection | Assembly | Auto parts assembly |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Metal press Measuring |
Auto parts manufacturing | Body part | Door Fender Other body parts |
Auto parts manufacturing | Exterior part | Wiper |
Auto parts manufacturing | Drive system part | Accelerator Steering device Brake parts |
Auto parts manufacturing | Engine | Cooling system Muffler Radiator parts |
Auto parts manufacturing | Interior part | Seat parts |
Product manufacturing | Others | Transportation equipment manufacturing Telecommunication equipment manufacturing |
