Powder sintering ( Development and production of prototype/Small-scale production / Prototype processing ) |
Plastic protocol machining( Development and production of prototype/Small-scale production / Prototype processing ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Vacuum molding( Mass production / Plastic ) |
Vacuum/Air pressure molding die( Die manufacturing / Plastic mold ) |
NC milling ( Development and production of prototype/Small-scale production / NC machining ) |
Photoforming( Development and production of prototype/Small-scale production / Prototype processing ) |
Company name |
有限会社 樹脂リードモデル (Jushiri-domoderu) |
Website URL | http://www.jrm-2001.com/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 10 |
Annual sales | 150,000,000 JPY | EMIDAS Member Number | 76826 |
Type of manufacturing | Home electrical appliances / Transportation equipment / Medical equipment |
Large | Medium | Small |
Material | Plastic material distribution | PVC (polyvinyl chloride) ABS resin PP (polypropylene) PE (polyethylene) PMMA (polymethyl methacrylate) PA (nylon/polyamide) PC (polycarbonate) PET (polyethylene terephthalate) POM (polyoxymethylene) FRP (fiber reinforced plastic) Urethane resin |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Profile milling Machining/Handles small-scale production (order from 1 piece) Aluminum alloy Machining (resin) Router machining Milling (resin) Lathe machining (resin) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling Handles 3D processing |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Photoforming Bending Small-size prototype manufacturing Vacuum injection molding Powder sintering Model manufacturing |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing NC data creation 3D modeling Vacuum/Air pressure molding die |
Mass production | Plastic | Vacuum molding Air pressure molding PVC (polyvinyl chloride) PMMA (polymethyl methacrylate) Engineering plastic FRP (fiber reinforced plastic) Urethane resin FRP molding (hand lay-up/spray lay-up) EP (epoxy) Handles small-scale production auto-clave) |
Surface treatment | Plating/Chemical conversion treatment | Plastic |
Surface treatment | Coating | Air-spray coating Resin coating Urethane coating Acrylic coating Lacquer coating Epoxy coating |
Surface treatment | Printing and others | NC engraving Engraving Silk screen printing Offset printing Silk (handles curved surface) |
Assembly/Inspection | Inspection | Plastic Measuring |
