Handles microfabrication( Development and production of prototype/Small-scale production / Machining ) |
Precision cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Nitrogen cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Thin plate (below 6 mm)( Development and production of prototype/Small-scale production / Blank cutting ) |
Casting( Designing / Simulation ) |
Plating( Designing / Simulation ) |
Cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Deep hole drilling( Development and production of prototype/Small-scale production / Machining ) |
Cutting( Designing / Simulation ) |
Precision equipment assembly( Assembly/Inspection / Assembly ) |
Company name | NANSHIN CO.,LTD. | Website URL | http://www.nanshin.com/en/ |
Street address |
Iijima-machi, Kamiina-gun Nagano Japan
[See map] |
Person in charge | Miwako Kageyama |
Telephone number | +81-265-86-3175 | Fax number | +81-265-86-4221 |
Capital | 70,000,000 JPY | Employees | 98 |
Annual sales | Unregister | EMIDAS Member Number | 76203 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Medical equipment | ||
Main 3 products |
Primary clients |
PR message
We handle development, manufacturing, and sales of ultra precise micro tubes that employ electroforming technology. While maintaining high precision, we are also able to manufacture fine-hole and long-hole pipes that cannot be made by cutting work or electric discharge machining.
・ Metal ferrule (fine thick-walled pipe)
Optical communications, fine hole jigs, fine mold parts, long nozzles, etc.
・ Micro tubes
Probe pin barrels, fine connectors , etc.
・ Multi-hole fine pipe, micro hole arrays
Optical communications, fine hole jigs, nozzles , etc.
・Taper pipe
Medical equipment, laser illumination devices, etc.
・Copper electrode pipe (large diameter)
Automotive industry, equipment industry, etc.
・Large diameter nickel pipe
Transfer rollers, equipment industry, etc.
Our company is a pioneer in the assembly industry, with over 40 years of assembly operations in IT-related machinery, etc. Let us handle your assembly needs, starting with OA machinery. We also handle metal workpieces and various equipment, jigs, and tools.
Most recent update:2025-01-09
Large | Medium | Small |
Designing | Mold designing | Casting die designing |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Designing | Electrical planning | Electrical machinery and apparatus designing |
Designing | Simulation | Casting Plating Cutting |
Development and production of prototype/Small-scale production | Machining | Deep hole drilling Iron Stainless steel High rigid material Aluminum alloy Nickel alloy Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Micro hole machining |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Nitrogen cutting Thin plate (below 6 mm) Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | Cylindrical grinding Centerless grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly |
