Most recent update: 2024-06-03
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 共栄精機 (Kyoueiseiki) |
Website URL | http://www.kyoeiseiki.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 15 |
Annual sales | 200,000,000 JPY | EMIDAS Member Number | 75578 |
Type of manufacturing | Telecommunication equipment / Industrial machinery / Lighting equipment |
Large | Medium | Small |
Designing | Product and part designing | Office equipment designing Medical equipment designing Measurement/testing device designing External design |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Industrial equipment designing | Industrial machinery designing |
Development and production of prototype/Small-scale production | Machining | Spinning Iron Stainless steel Aluminum alloy Milling (resin) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Model manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining NC data creation Drawing die Bending die Blanking die Progressive die Single press die Below 60 t 60 - 300 t Sash molding die Compound die |
Die manufacturing | Rubber mold | Designing Blanking die Packing-related products Home electrical appliances Mobile phones |
Mass production | Metal press | Drawing Bending Blanking Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Black chromium (barrel) Chromate (general) Gold/Silver plating Chromium (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Electroless nickel (barrel) Electroless nickel (rack) Trivalent Chromate (barrel plating) Iron Brass Aluminum Stainless steel Other anti-rust treatments Hard chromium (rack) Degreasing Black oxide finish Colored alumite Hard alumite Hot-dip galvanizing (large-size Unichromate (white) Black chromate (black/green) |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Construction component assembly Industrial machinery assembly |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing Cabinetmaking |
