Punching( Development and production of prototype/Small-scale production / Prototype processing ) |
Blanking( Mass production / Rubber ) |
Sponge( Development and production of prototype/Small-scale production / Machining ) |
Sponge( Mass production / Mechanical processing ) |
Injection molding ( Mass production / Plastic ) |
Water jet processing( Mass production / Blank cutting ) |
Urethane( Development and production of prototype/Small-scale production / Machining ) |
Manual labor( Assembly/Inspection / Side job processing ) |
Expansion molding( Mass production / Plastic ) |
Transport agents( Material / Industrial waste / Recycling ) |
Company name | FUJIKA KOUGYO Co.,Ltd. | Website URL | http://www.fujika-kogyo.co.jp/ |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 23 |
Annual sales | Unregister | EMIDAS Member Number | 72493 |
Type of manufacturing | Industrial machinery / Medical equipment / Leisure goods |
Large | Medium | Small |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Material | Plastic material distribution | PVC (polyvinyl chloride) ABS resin PP (polypropylene) PE (polyethylene) PMMA (polymethyl methacrylate) PA (nylon/polyamide) PC (polycarbonate) PET (polyethylene terephthalate) POM (polyoxymethylene) PPS (polyphenylene sulfide) PEEK (polyetheretherketone) Fluororesin PF (phenol-formaldehyde) GFRP (glass fiber reinforced plastic) Urethane resin PU (polyurethane) EP (epoxy) PES (polyethersulfone) |
Material | Industrial waste / Recycling | Transport agents |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) Machining (resin) Router machining Milling (resin) Lathe machining (resin) Urethane Sponge |
Development and production of prototype/Small-scale production | Blank cutting | Water jet cutter machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Plastic bonding High-frequency welding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Bending Simplified/Molding |
Die manufacturing | Cutting dies | Thomson punch Corrosion blade cutting die |
Mass production | Mechanical processing | Urethane Sponge |
Mass production | Plastic | Blow molding Vacuum molding Extrusion molding Insert molding Expansion molding Air pressure molding PVC (polyvinyl chloride) General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PEEK (polyetheretherketone) Fluororesin Thermoset resin FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) Urethane resin PU (polyurethane) Elastomer Injection molding PES (polyethersulfone) EP (epoxy) Handles small-scale production Pipe extrusion molding Tube extrusion molding Special shape extrusion molding CFRP (carbon fiber reinforced plastic) Sheet / film processing |
Mass production | Rubber | Rubber product prototype manufacturing Compression molding Transfer molding Blanking Silicon rubber Urethane rubber Butyl rubber NBR SBR CR EPT Fluoro-rubber and other auto parts Packing-related products binoculars and optical products Home electrical appliances Mobile phones Light electrical/earthing rubber Medical Press stamping Extrusion molding Weather-ability Weight saving Thermostability Electric property Chemical proof Machine tools/Equipments Manufacturers Architecture Vulcanization adhesion |
Mass production | Blank cutting | Water jet processing |
Mass production | Welding / welding | Plastic adhesive High frequency welder processing |
Assembly/Inspection | Side job processing | Manual labor |
