Cylindrical grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Cylindrical mirror grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Plane grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Industrial machinery designing( Designing / Industrial equipment designing ) |
Company name | HONDASEIKI CO,LTD | Website URL | |
Street address |
Wakabayashi Ward, Sendai City Miyagi Japan
[See map] |
Person in charge | honda |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 15,000,000 JPY | Employees | 30 |
Annual sales | 1,000,000,000 JPY | EMIDAS Member Number | 72345 |
Type of manufacturing | Jigs and tools / Machine tools / Industrial machinery | ||
Main 3 products |
PR message
We have a production system that integrates various processes such as machine design, machining, welding, fusion cutting, sheet metal processing, surface treatment, assembly, adjustment testing, installation work, etc, units, parts, etc.
We offer a wide range of services, from design to machining, sheet metal/welding, surface treatment, assembly/adjustment/installation.
We accept requests from one-off items such as parts processing, prototypes, and assembly of precision machinery and experimental equipment.
Please feel free to contact us as we also perform modification processing of equipment parts.
We have large processing equipment, so if you are looking for a large processing destination, please contact us.
Most recent update:2023-07-12
Large | Medium | Small |
Designing | Product and part designing | Measurement/testing device designing |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Plant equipment designing Precision automatic machinery designing Industrial machinery designing Food industry machinery designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Planer machining Deep hole drilling Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Molybdenum alloy Machining (resin) Keyway milling Automatic lathe Shaper machining Lathe machining (resin) Casting Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Sheet metal protocol manufacturing Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic 3D laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Jig grinding Cylindrical mirror grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Mechanical processing | Machining NC turning machining Five-face/axes machining Complex turning machining Iron Stainless Aluminum alloy Copper alloy Turning machining(plastic) Casting |
Mass production | Sheet-metal processing | Can-making Pipe bender processing Deburring process Bending process |
Surface treatment | Plating/Chemical conversion treatment | Iron Aluminum Stainless steel Hard chromium (rack) |
Surface treatment | Coating | Air-spray coating Urethane coating Lacquer coating |
Surface treatment | Polishing/Lapping | Buffing Mirror polishing |
Surface treatment | Other surface treatment | Buffing Sound blast |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Repair | Industrial machinery repair |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Machinery part | Crank shaft manufacturing Shaft and roller manufacturing Ring |
Product manufacturing | Production property | Other industrial machinery manufacturing |
