NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Compression molding die( Die manufacturing / Rubber mold ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Mass production jig manufacturing( Development and production of prototype/Small-scale production / Jig manufacturing ) |
General-purpose lathe machining( Development and production of prototype/Small-scale production / Machining ) |
Handles 3D processing( Development and production of prototype/Small-scale production / NC machining ) |
Packing-related products( Die manufacturing / Rubber mold ) |
Rubber mold part processing( Die manufacturing / Rubber mold ) |
Part processing( Die manufacturing / Press die ) |
Company name | SUZUSEIKI Co., Ltd | Website URL | https://gomu-kinzoku-shisaku.com/ |
Street address |
Shuchi-gun Shizuoka Japan
[See map] |
Person in charge | Tadatoshi Suzuki |
Telephone number | +81-538-48-8916 | Fax number | +81-538-48-8451 |
Capital | 5,000,000 JPY | Employees | 10 |
Annual sales | Unregister | EMIDAS Member Number | 63012 |
Type of manufacturing | Transportation equipment / Jigs and tools / Medical equipment | ||
Main 3 products |
PR message
~~~ If you want to make rubber and metal prototype, please leave it to us! ~~~
・ We deliver rubber prototypes with the same quality as mass production in a minimum of 3 days! Of course, we also can handle mass-production.
・We handle prototype and mass production of various metal processing.
・ Please leave the design and manufacture of various rubber molds, from prototype molds to mass production molds, compression molds to injection molds to us.
* Contents: Parts processing, machining, cutting, metal parts, lathe processing, NC lathe processing, milling, machining, machining center processing, 5-axis processing, mold parts
* Materials: iron, steel, stainless steel, aluminum, copper, brass, resin, etc.
* Range: Compatible with round objects of Φ1 to Φ300 and square objects of 10 x 10 to 1000 x 550.
We aim to be a helpful "your town factory".
Business items: Rubber mold design and manufacturing, various parts processing, jig and tool design and manufacturing * ISO9001 qualified
~ We are good at rubber & metal product prototypes and small lots production ~
[Rubber prototype] *Mass-produced products are also available.
◎ Vulcanized molded products, rubber molded products, cutting products, cast molding, 3D printers
"We will deliver the optimum prototype in consideration of delivery time, quality and cost"
[Metal prototype] * Mass-produced products are also available.
Applicable materials: iron, steel, stainless steel, aluminum, copper, brass, resin, etc.
Range: compatible with round objects of Φ1 to Φ300 and square objects of 10 x 10 to 1000 x 550
We process with lathe, slice machine, machining, grinding machine, electric discharge machine.
[Rubber mold]
We can handle prototype and mass production mold.
◎ Compression mold / Compression injection mold / Injection mold
* Compatible with various products such as O-rings, gaskets, dampers, grommets, and hoses.
Most recent update:2023-04-01
Large | Medium | Small |
Designing | Mold designing | Injection molding die 3D modeling (press) NC data creation (press) |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Machining (resin) Automatic lathe Bench lathe machining Milling (resin) Lathe machining (resin) Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Combined lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding Cylindrical grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
Die manufacturing | Press die | Part processing Plate machining |
Die manufacturing | Plastic mold | Part processing Plate machining Mold base machining |
Die manufacturing | Rubber mold | Designing Rubber mold part processing Part processing 3D modeling Compression molding die Transfer molding die and other auto parts Packing-related products binoculars and optical products Home electrical appliances Mobile phones Light electrical/earthing rubber Medical Sundries and shoes |
Assembly/Inspection | Repair | Die repair |
