Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Energy-saving machinery designing( Designing / Industrial equipment designing ) |
Software designing( Designing / Electrical planning ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Chassis manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
Thin wall (Thickness: 0.5 or less)/small-size sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Fiber laser processing( Development and production of prototype/Small-scale production / Blank cutting ) |
Aluminum( Surface treatment / Plating/Chemical conversion treatment ) |
Coating( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name | Sanmatsu Co., Ltd. | Website URL | |
Street address |
Chikushino Fukuoka Japan
[See map] |
Person in charge | |
Telephone number | +81-92-926-4711 | Fax number | +81-92-926-2048 |
Capital | 85,000,000 JPY | Employees | 178 |
Annual sales | 3,330,000,000 JPY | EMIDAS Member Number | 5215 |
Type of manufacturing | Industrial machinery / Electronic parts / Medical equipment | ||
Main 3 products |
Primary clients |
PR message
Our factory can handle machinery design, control software development, parts processing, assembly and OEM for orders ranging from single prototypes to 1,000s of units with sheet metal parts processing with thickness ranging from ultra-thin 0.01 mm to 22 mm.
We've acquired the ISO 9001 and 14001 standards. Our motto is "Respond to customer demands, no matter how difficult," and our company does all it can for fine quality and timely delivery--things the customer should naturally be provided. Make use of our production management agency, our OEM and EMS manufacturing agents and our factory as your dedicated production facility in Kyushu.
Most recent update:2025-02-03
Large | Medium | Small |
Designing | Industrial equipment designing | Energy-saving machinery designing |
Designing | Electrical planning | Software designing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Laser marking Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Metal press | Single press (200 - 500 t) |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Black chromium (barrel) Chromate (general) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Iron Aluminum Degreasing Black oxide finish Colored alumite Hard alumite Hot-dip galvanizing (mid-size Hot-dip galvanizing (large-size Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrostatic coating Melamine coating Urethane coating Acrylic coating Epoxy coating Electrical insulating Heat insulation coating Heat-resistant coating Metal coating Fluorine coating |
Surface treatment | Polishing/Lapping | Electropolishing Tool polishing |
Surface treatment | Printing and others | Silk screen printing |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Teflon coating Buffing |
Assembly/Inspection | Assembly | Office equipment assembly Construction component assembly Industrial machinery assembly |
Product manufacturing | Production property | Machine tool manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Measurement/testing devices manufacturing Freezer equipment manufacturing Food industry machinery manufacturing Chemical industry machinery and equipment manufacturing Monitoring device manufacturing Environmental equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Combustor manufacturing Construction and civil engineering material manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing Transportation equipment manufacturing Telecommunication equipment manufacturing |
