PR message
At Kimura Industry, we provide full-scale manufacturing, from cutting and grinding to assembly, from small-scale production of multiple products to assembly. Even if you have been placing orders with multiple factories until now, we hope you'll consult with us. We'll respond with proficient skill and solid results.
We currently offer machine tool parts, semiconductor and liquid crystal production equipment parts, industrial machinery parts, aircraft parts, racing car parts and more.
We integrate multiple processes in our manufacturing: lathes, milling, quenching and grinding. Taper gauge processing precision, when tightened (12 kg/m 80%+ ensured for each), is within squareness of 0.003, deviation of 0.003 and plane aperture of 0.005. For other precision grinding, we handle a max of φ200 x 200.
In particular, our highest area of expertise is cylindrical grinding and bore grinding of mating parts, as well as tapered mating parts. We handle tolerance on the micron level that cannot be produced simply with machining techniques. This includes square grinding, internal grinding and high-precision tapered grinding.
6 machining centers, 700 x 700 x 500
3 NC cylindrical grinders, 150 x 150 x 500
2 NC plane grinders, 600 x 500 x 250
6 NC lathes, 150 x 150 x 400
4 NC milling machines, 800 x 400 x 500
1 wire cutter, 400 x 400 x 150
3 bore grinders
1 internal grinder
4 six-foot lathes
* Feel free to contact us. *
Leave the grinding to Kimura Industry, whether it be cylindrical grinding, bore grinding, internal grinding, surface grinding, jig grinding, etc.
We integrate multiple processes in our manufacturing: lathes, milling, quenching and grinding. Taper gauge processing precision, when tightened (12 kg/m 80%+ ensured for each), is within squareness of 0.003, deviation of 0.003 and plane aperture of 0.005. For other precision grinding, we handle a max diameter of 200 x 200.
We handle 2-D and 3-D solid model processing and production as well as of round, round composite and square parts made of iron, stainless steel and aluminum. We can also shift to processing based just on your data and diagrams.
High-precision external grinding of special tool steel (HRC65 and better)
Max: diameter 100, 300 L
We handle tolerance on the micron level that cannot be produced simply with machining techniques. This includes square grinding, internal grinding and high-precision tapered grinding of iron, stainless steel, non-ferrous metals such as aluminum and ceramics and more.
Cylindrical grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Company name | Kimura Industry Co., Ltd. | Website URL | |
Street address |
Nagaokakyo Kyoto Japan
[See map] |
Person in charge | 山田 大介 |
Telephone number | +81-75-953-2721 | Fax number | +81-75-951-2267 |
Capital | 20,000,000 JPY | Employees | 30 |
Annual sales | 500,000,000 JPY | EMIDAS Member Number | 49073 |
Type of manufacturing | Machine tools / Industrial machinery / Jigs and tools | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Designing | Simulation | 3D modeling |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Keyway milling Automatic lathe Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Casting Handles microfabrication Handles microfabrication Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Boring milling Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Jig boring Jig grinding Internal grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
Surface treatment | Polishing/Lapping | Mirror polishing |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Shaft and roller manufacturing |
Parts manufacturing | Electric board and electronic part | Electronic parts assembly and wiring |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Industrial robot manufacturing Semiconductor manufacturing equipment manufacturing |
