PR message
Our company specializes in the manufacture of single parts and jigs, and molds.
We can perform cutting and grinding after heat treatment of hard-to-process (cemented carbide, ceramic) and high hardness (powder high-speed steel HRC 65 ~) materials.
We also specializes in polishing.
Other services we provide:
・Improvement in surface roughness, mirror finish, lapping process.
・Pretreatment and treatment for surface roughness before coating (CVD, PVD)
・Offer suggestion regarding surface roughness before coating treatment (CVD, PVD) and pretreatment.
・Attachment of various inspection and measurement data.
3D measuring machine, shape measuring machine, roundness measuring machine, roughness measuring machine, 3D image measuring machine
・Reverse engineering. We can make a drawing of product without drawing by measuring the actual product.
・Super quick production. Using materials we have such as SKH, SKD, SKS, SNCM (size limited), we can perform cutting (lathe, machining) → heat treatment (with heat treatment furnace) → polishing (outer diameter, flat surface, inner diameter, copying) → electric discharge machining (engraving electric discharge, wire discharge) until finishing (polishing) in the shortest time.
Please contact us for line stop, urgent production, prototype, etc.
◆◆ Materials we can handle ◆◆
All sorts of S45C, S50C, S55C
SS41, SS400
SCM415, SCM420, SCM435, SCM440, SCM445
SKD1, SKD4, SKD5, SKD6, SKD7, SKD8, SKD11, SKD12, SKD61, SKD62
SKH4, SKH1 0, SKH40, SKH51, SKH55, SKH57
HPM, NAK
CFRP, GFRP
A1070, A2017, A3003, A4032, A5052, A6061, A7075
Hard alumite treatment
SUS303, SUS304, SUS310, SUS316, SUS403, SUS416, SUS420, SUS440J2, SUS440C, SUS630, etc.
Copper (BC3, BC6, BC7, CAC403, CAC406, CAC407), pure copper, beryllium copper, zirconium copper, brass
All sorts of Copper Phosphate (CAC502A, CAC502B, PBC2, PBC2B)
pure titanium, Ti-6Al-4V (titanium alloy), forged titanium, cast titanium
Inconel, Inconel 600, Inconel 625, Inconel 718, Inconel X750, Hastelloy, Invar, aging treatment (in-house available)
iron, aluminum alloy, copper, brass, etc.
cemented carbide, fine particles, ultra fine particles V1 to V10, G1 to G10
ceramic, silicon carbide (SiC), silicon nitride (Si3N4), various Alumina zirconia,
all sorts of resin, nylon, rubber,
teflon, nickel, hard chrome plating, various surface treatments
all sorts of CVD, PVD coating, carbide spraying, ceramic spraying
We can also perform precision welding, overlaying, etc.
We are updating our company staff canteen meal everyday on Instagram!
https://www.instagram.com/rhineseikou/?hl=ja
November 12, 2020
Certified as Habataku Small Medium Enterprise of small business 300 companies.
Ceramic, insulation, abrasion measurement
Polishing, profile processing, adhesion of various materials
Adhesion and polishing of steel and ceramic
The inner diameter part is abrasive machined and polished.
Please contact us for single item and improvement.
We are good at cemented carbide and cutting after quenching.
We are also good at cutting and polishing of high-hardness materials such as SKD, SKH, and cemented carbide. We also handle abrasive machining, electric discharge machining and finishing polish.
Please contact us for various special steels, various cemented carbides, various ceramics (SIC, ZRO2, etc.)
cutting, EDM, grinding, polishing, special and custom products.
We perform cutting, quenching, grinding, polishing, shrink fitting, freeze fitting, inspection (3D, shape, image measurement, etc.) in-house.
We handle SKD, SKH, carbide and good at small lot and single item production.
※※ Please contact us for urgent production.
We manufacture various precision metal processing, mold peripheral parts, machine parts and jigs.
Not only drawings, we can handle production from the actual product to measurement, drafting, and processing.
We also propose materials.
In addition, we also manufacture products for the aircraft industry and medical devices.
Please feel free to contact Rhine Seiko in Kakamigahara City, Gifu Prefecture to order various precision parts processing.
The shape of the cutting edge is profiled on cemented carbide.
After quenching and heat treatment, the thin material is finished by cutting and polishing.
Φ7 × Φ6 × 185
There is a window hole, as the point to minimize distortion.
SKH-55 HRC64 ~
The embossed shape is finished by cutting after quenching and after heat treatment.
To prevent abrasion, ceramic is adhered and then finished by polishing at the same time.
(SKD11 & Zro2)
We specialize in processing after quenching and processing after heat treatment.
Quenching can increase the hardness, but it makes processing difficult.
High-hardness materials HRC60~.
We are good at single item production.
We manufacture parts and special products used in dedicated machines.
We perform integrated production from the actual product → drawing → finish product.
Dedicated special collet chuck
We perform everything from manufacturing to adjustment of special jigs, clamp jigs, and inspection jigs.
We apply abrasion resistant coating on the wear part.
Cold forging die( Die manufacturing / Forging die ) |
Company name | Rhine Seiko Co.,Ltd | Website URL | http://www.rhine-s.co.jp |
Street address |
Kakamigahara-shi Gifu Japan
[See map] |
Person in charge | Toru Nagase |
Telephone number | +81-58-386-8161 | Fax number | +81-58-386-8266 |
Capital | 28,000,000 JPY | Employees | 31 |
Annual sales | Unregister | EMIDAS Member Number | 47139 |
Type of manufacturing | Jigs and tools / Machine tools / Measuring machinery | ||
Main 3 products |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) High rigid material Ceramic |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding Cylindrical grinding Profile grinding Jig grinding Cylindrical mirror grinding Internal grinding NC internal grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Die manufacturing | Press die | Manufacturing Part processing Plate machining Die set machining Drawing die Bending die Blanking die Shaving die Progressive die Transfer press die |
Die manufacturing | Powder metallurgy mold | Manufacturing Powder metallurgy mold part manufacturing Ceramic die High rigid die |
Die manufacturing | Forging die | Designing Manufacturing Forging die part processing Hot forging die Cold forging die Press forging die |
