Gear manufacturing( Parts manufacturing / Machinery part ) |
Injection molding die( Die manufacturing / Plastic mold ) |
Plastic protocol machining( Development and production of prototype/Small-scale production / Prototype processing ) |
Part processing( Die manufacturing / Plastic mold ) |
Below 60 t( Die manufacturing / Plastic mold ) |
60 - 300 t( Die manufacturing / Plastic mold ) |
Die-casting die( Die manufacturing / Casting die ) |
Insert molding( Mass production / Plastic ) |
Manufacturing( Die manufacturing / Plastic mold ) |
Engineering plastic( Mass production / Plastic ) |
Company name | Chiba Dies Co., Ltd. | Website URL | http://www.chibadies.co.jp/ |
Street address |
Yashio City Saitama Japan
[See map] |
Person in charge | 千葉英樹 |
Telephone number | +81-48-997-6621 | Fax number | +81-489-97-6625 |
Capital | 48,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 39088 |
Type of manufacturing | Industrial machinery / Home electrical appliances / Transportation equipment | ||
Main 3 products |
Primary clients |
PR message
We are a gear manufacturer specializing in plastic and metal gears, prototyping, mold making, mass production, and testing. We have a tribology laboratory for plastic gears, and we can provide consistent support such as noise tests, durability tests, and material development support.
[GEAR+]
For resin gears, we have a solution site for solving all kinds of problems such as noise, durability, accuracy, etc.
[Speed Tri]
A best-in-class low-volume production service, Speed Tri enables prototyping and repeat molding using the same production methods as mass production, with gears delivered in as little as 3 days!
[CD Machining]
CD Machining is the process of drawing a long bar (2.5m) such as free-cutting steel, brass, or aluminum to form a finished product.
The accuracy is high, and you can expect a significant cost reduction for products that were previously processed by hobbing, milling, or wire processing.
[Rolling Worm]
We manufacture by cutting and increasing the surface roughness of the worm gear. Highly recommended as we receive requests from customers who prefer the surface roughness of the worm gear. The worm gears are mass-produced products with beautiful tooth surfaces. We successfully produce several million units per year.
[Hyper-lead Screw]
For those who consider weight reduction and fast movement, which were thought to be unachievable for conventional lead screws.
[Why choose Chiba Dies?]
Excerpts from surveys of our regular customers
>Company M, motor industry
We had been struggling for many years with noise reduction measures for our gear drive unit, but after we changed to the gears Chiba Dies suggested, it became so quiet that we could hear and see the difference. Moreover, as an amateur with limited knowledge of gears, I learned a lot from the tips you gave me on how to design gears that would be even quieter. I am looking forward to trying this technique in my next development project!
>Company K, E-bike industry
We had never molded gears in our company before, so we were very anxious at first. We started from zero in the selection of a molding machine, but thanks to Chiba Dies’ generous advice on professional knowledge and technology, and their constant follow-up, we were able to start mass production with peace of mind. We also received kind and detailed guidance on gear accuracy and were even taught a simple measurement method that we can use onsite, which will be very useful for quality control.
Other Gear Solutions:
SpeedTriCut, a cutting prototype service:
1. No special tooling is required for modified tooth profile, high gear tooth, and transverse shift
2. Reusability of mass-production materials
3. Machining can be done by CNC hobbing machine or high-precision 5-axis machining
[Gear Testing & Measuring Service]
1. Strength and durability testing of plastic gears
2. Noise test of plastic gears
3. Accuracy and meshing test of plastic gears
4. Gear fret inspection tool for easy quality control on site
[Environment, Accuracy, Productivity, Durability]
1. Insert molds for EVs and E-bikes
2. Experience with super engineering plastic molds such as PEEK
3. Mold design considering material reduction and resource recycling
4. Customer support is available all around!
[Carbon-neutral gear production!]
1. Inquiries about gear production for E-bikes and EVs are increasing!
2. In-house production of molds and insert parts for emergency response
3. Proposal for resource recycling such as reduction of waste plastic
4. Proposals for appropriate quality assurance are available upon request.
One-stop solution for plastic gear issues!
1. Which molding material is best?
2. I'm buying gear but want to produce them in-house.
3. Who is your partner for a new project?
4. I want to present the advantages of our molding materials to our customers.
We look forward to hearing from you!
TEL: 048-997-6621
For sales, contact: Uehara"
Most recent update:2023-06-19
Large | Medium | Small |
Designing | Product and part designing | Gear designing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining |
Die manufacturing | Press die | Manufacturing Part processing |
Die manufacturing | Plastic mold | Manufacturing Part processing Injection molding die Insert molding die Below 60 t 60 - 300 t |
Die manufacturing | Casting die | Manufacturing Die-casting part processing Die-casting die |
Mass production | Plastic | Insert molding General-purpose material Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) Below 60 t 60 - 300 t Injection molding |
Parts manufacturing | Machinery part | Gear manufacturing |
