YAG laser machining( Development and production of prototype/Small-scale production / Blank cutting ) |
Pipe machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Fiber laser processing( Development and production of prototype/Small-scale production / Blank cutting ) |
Housing manufacturing( Mass production / Sheet-metal processing ) |
Stainless steel( Development and production of prototype/Small-scale production / Machining ) |
Copper alloy( Development and production of prototype/Small-scale production / Machining ) |
Copper/Aluminum( Development and production of prototype/Small-scale production / Blank cutting ) |
Company name | TAKANO Co., Ltd. | Website URL | http://www.takano-s.co.jp/ |
Street address |
Matsumoto-Shi Nagano Japan
[See map] |
Person in charge | Yas takano |
Telephone number | +81-263-48-1500 | Fax number | Log in to display |
Capital | 10,000,000 JPY | Employees | 120 |
Annual sales | 1,600,000,000 JPY | EMIDAS Member Number | 33491 |
Type of manufacturing | Industrial machinery / Office automation equipment / Medical equipment | ||
Main 3 products |
PR message
TAKANO is a leading company in precision sheet metal processing.
<Metal 3D Printer Contract Manufacturing Business>
■Owned facility
TRUMPF TruPrint 1000
▷OVER VIEW
Laser Metal Fusion for complex, metallic components.
The TruPrint 1000 is the most productive machine in compact form and offers you all the benefits of additive manufacturing. It can be used to create components in almost any geometric shape. Even complex shapes can be quickly and easily converted from the CAD design to a 3D metallic component – and with top quality. You can use the TruPrint 1000 for the generative production of small industrial single parts and series.
■Technical data
▷Build volume:Φ96mm × H86mm
▷Beam diameter:Φ55μm
▷Materials:Stainless steels,Mariaging steel,Aluminum,Cobalt-chrome,Nickel alloy,Titanium,copper(metal plating)
▷Dimensions precision:0.1-0.15mm degree
▷Surface roughness:Ra9±3μm(Stainless)
We can mold the complicated shape, and quick delivery!
If you have any questions,please contact us!
■Person in charge
Sotaro "FUJI" Fujio
Leader, 3D Printer Department TAKANO Co., Ltd.
Mail:fujio@takano-s.co.jp
Most recent update:2023-08-30
Large | Medium | Small |
Designing | Jig and tool designing | Welding jig designing |
Designing | Simulation | 3D modeling |
Development and production of prototype/Small-scale production | Machining | Tapping Iron Stainless steel Aluminum alloy Copper alloy Brass |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) 3D pipe machining Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Laser marking Thin plate (below 6 mm) Stainless steel Copper/Aluminum Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Robot welding Stud welding YAG laser machining Fiber welding Projection welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Sheet-metal processing | Pipe processing Can-making Air conditioning equipment manufacturing Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Bender processing (over 3.0m) Pipe bender processing Deburring process Painting process Mirror surface material processing Hairline processing 3-roll machine Bender processing (servo) 3D pipe processing Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Laser marking YAG laser processing Turret punch punching Cutting process Laser and turret punch punching Laser processing (over 1.2m) Connor Shah Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum |
Mass production | Welding / welding | Projection welding CO2 welding Fiber welding Spot welding TIG welding (argon welding) Robot welding Stud welding YAG laser processing |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Colored alumite Hard alumite Hard alumite (large) |
Surface treatment | Coating | Air-spray coating Powder coating Aqueous coating Melamine coating Acrylic coating |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Printing and others | Silk screen printing |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Other surface treatment | Buffing |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Parts manufacturing | Electric board and electronic part | Electronic parts assembly and wiring |
Parts manufacturing | Other parts | Sign board manufacturing |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Measurement/testing devices manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing Telecommunication equipment manufacturing |
