PR message
The three-dimensional design and production of the die by CATIA. It is supported a great variety of products until plastic, a die, the product mass production of the precision part mainly by a press die design, the production of motor parts.
General metal press die( Designing / Mold designing ) |
Company name | TSUBAMEX Co., Ltd, | Website URL | |
Street address |
Nishikan-ku Niigata Japan
[See map] |
Person in charge | Hikaru Itokawa |
Telephone number | +81-25-375-4168 | Fax number | +81-25-375-5359 |
Capital | 40,000,000 JPY | Employees | 176 |
Annual sales | 3,803,000,000 JPY | EMIDAS Member Number | 33450 |
Type of manufacturing | Industrial machinery / Kitchen / Transportation equipment | ||
Main 3 products |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die Extrusion molding die designing 3D modeling (press) 3D modeling (plastic) NC data creation (press) NC data creation (plastic) |
Designing | Simulation | 3D modeling CAE fluid analysis |
Development and production of prototype/Small-scale production | Sheet-metal processing | Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing |
Die manufacturing | Press die | Designing Manufacturing Part processing NC data creation 3D modeling Drawing die Bending die Blanking die Forming die Progressive die Transfer press die Single press die 60 - 300 t Over 300 t Compound die |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining 3D modeling Injection molding die Insert molding die 60 - 300 t 000 t |
Mass production | Metal press | Drawing Bending Blanking Forming Fine blanking Multi forming Shaving Coining Iron Stainless steel Aluminum Copper Brass Plated steel plate Stainless steel material for spring Thickness Thickness Diameter φ0.6mm - φ9.0mm Press robot (80 -200 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Plastic | Insert molding Outsert molding General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) Elastomer Below 60 t 60 - 300 t 000 t Injection molding |
Surface treatment | Plating/Chemical conversion treatment | Degreasing |
Assembly/Inspection | Assembly | Construction component assembly |
Product manufacturing | Production property | Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Combustor manufacturing Construction and civil engineering material manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
