Injection molding die( Die manufacturing / Plastic mold ) |
Insert molding die( Die manufacturing / Plastic mold ) |
Thermoset resin die( Die manufacturing / Plastic mold ) |
Blow molding die( Die manufacturing / Plastic mold ) |
Vacuum/Air pressure molding die( Die manufacturing / Plastic mold ) |
Simple mold, prototype mold( Development and production of prototype/Small-scale production / Prototype processing ) |
Injection molding ( Mass production / Plastic ) |
Small-lot/Injection molding( Development and production of prototype/Small-scale production / Prototype processing ) |
Prototype/Small-lot molding( Development and production of prototype/Small-scale production / Prototype processing ) |
Die repair( Assembly/Inspection / Repair ) |
Company name | MIYUKI CO.,LTD | Website URL | https://www.miyuki-mold.co.jp |
Street address |
Takaoka-shi Toyama Japan
[See map] |
Person in charge | Akiyoshi Kubota |
Telephone number | +81-766-31-0646 | Fax number | +81-766-31-0647 |
Capital | 16,000,000 JPY | Employees | 25 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 24924 |
Type of manufacturing | Transportation equipment / Medical equipment / Stationery products | ||
Main 3 products |
PR message
Miyuki is a company that designs and manufactures molds for plastic molding in Takaoka City, Toyama Prefecture. We have a track record in unscrewing of foods, pharmaceuticals, medical equipment, cosmetics, others (motors, racks, etc.), large number of molds using hot runners for round products, and molds for engineering plastics and super engineering plastics with complicated mechanisms such as automotive and semiconductors.
We manufacture molds with particular attention to processing accuracy that lead to shorten the construction period of T0 to the beginning of mass production (reduce the number of TRYs). We are highly rated for our high durability, cycle-up, and trouble-free during mass production molding. In addition, we can handle mold prototype production of 50 to 450 tons to prototype TRY, so even for distant customers, it is possible to order molded products only without frequent mold traffic.
Most recent update:2025-02-25
Large | Medium | Small |
Designing | Mold designing | Injection molding die 3D modeling (plastic) NC data creation (plastic) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Simultaneous 5-axis machining Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Combined lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding Cylindrical grinding Internal grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Prototype/Small-lot molding Small-lot/Injection molding Simplified/Molding prototype mold |
Die manufacturing | Press die | Part processing Plate machining Die set machining |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining NC data creation 3D modeling Injection molding die Blow molding die Vacuum/Air pressure molding die Extrusion molding die Insert molding die Outsert molding die Below 60 t 60 - 300 t 000 t Electrode manufacturing Cassette-type molding die Thermoset resin die Thin wall injection molding die Injection molding die for microfabrication (5 mm or smaller) Core and cavity machining |
Die manufacturing | Casting die | Lost-wax casting die |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Wire machining Screw cutting machining Micro-hole machining Electrical discharge machining Iron Stainless Aluminum alloy Copper alloy Fine particle material accepted |
Mass production | Plastic | Insert molding General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) LCP (liquid crystal polymer) FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) Urethane resin PU (polyurethane) Elastomer Below 60 t 60 - 300 t Injection molding PES (polyethersulfone) EP (epoxy) Handles small-scale production Biodegradable plastic CFRP (carbon fiber reinforced plastic) |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Plastic |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
