Aluminum alloy( Development and production of prototype/Small-scale production / Machining ) |
Optical parts manufacturing( Parts manufacturing / Machinery part ) |
Combined lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Stainless steel( Development and production of prototype/Small-scale production / Machining ) |
Iron( Development and production of prototype/Small-scale production / Machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Copper alloy( Development and production of prototype/Small-scale production / Machining ) |
Company name | Horikoshi Seiki Co., Ltd. | Website URL | |
Street address |
Ohta-ku Tokyo Japan
[See map] |
Person in charge | Tomoko Hiramatsu |
Telephone number | +81-3-3761-5533 | Fax number | +81-3-3763-7821 |
Capital | 16,000,000 JPY | Employees | 34 |
Annual sales | 1,116,810,000 JPY | EMIDAS Member Number | 21314 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Medical equipment | ||
Main 3 products |
Primary clients |
PR message
We solve your problems. We can handle everything up to assembly, mainly with NC lathes and machining centers. What are your unit cost, quality and design problems? Horikoshi Seiki can consult you on these issues. Production volume from 10 to 10,000 units and sizes from 1 mm to 200 mm are OK.
Simple and difficult items are OK. Five-axis processing is OK. As for materials, we mainly handle metals, but resins are also OK.
Please contact us. We have a huge advantage in three important areas: delivery, quality and unit cost.
Most recent update:2024-01-19
Large | Medium | Small |
Designing | Industrial equipment designing | Industrial machinery designing Food industry machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Sintered metal Broaching Keyway milling Automatic lathe Bench lathe machining Simultaneous 5-axis machining Milling (resin) Air chuck equipment Lathe machining (resin) Casting Handles microfabrication Honing Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Combined lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Cylindrical grinding Internal grinding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromate (general) Nickel (rack) Alumite (anode oxidation) Electroless nickel (barrel) Electroless nickel (rack) Trivalent Chromate (barrel plating) Black oxide finish Hard alumite Unichromate (white) Black chromate (black/green) |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Construction component assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Gear manufacturing Valve manufacturing Bearing manufacturing Vacuum components manufacturing Pressure container manufacturing Connection parts manufacturing Magnet containing products manufacturing Crank shaft manufacturing Optical parts manufacturing Shaft and roller manufacturing Measurement devices manufacturing |
