Fiber laser processing( Mass production / Blank cutting ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Progressive press (200 - 500 t)( Mass production / Metal press ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Robot welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Precision equipment assembly( Assembly/Inspection / Assembly ) |
Copper / aluminum( Mass production / Blank cutting ) |
Angle processing( Mass production / Sheet-metal processing ) |
Thick plate 6 mm or more( Mass production / Blank cutting ) |
Company name | Irifune Technica Co., Ltd. | Website URL | http://www.irifune-tec.com/index.html |
Street address |
Takasaki City Gunma Japan
[See map] |
Person in charge | |
Telephone number | +81-27-374-0522 | Fax number | +81-27-374-4761 |
Capital | 20,000,000 JPY | Employees | 46 |
Annual sales | EMIDAS Member Number | 1375 | |
Type of manufacturing | Heavy electric machinery / Construction material / Office appliances | ||
Main 3 products |
Primary clients |
PR message
We meet our customers' demands for precision sheet metal fabrication with the latest equipment such as fiber laser processing machines and punch/laser combination machines. We specialize in fabricating iron, aluminum, stainless steel, copper, brass, etc. We design and manufacture sheet metal products, architectural products, and various precision sheet metal processing, and we can handle everything from prototype to mass production.
◆Press Molding◆
The Haruna Plant covers an area of 9,900 m2 and has various types of press machines ranging from a 400-ton progressive link motion press, a 200-ton progressive press, and 110-ton and 45-ton small presses. We will provide products that satisfy customers in terms of quality, delivery, and cost by using the most suitable processing method per their requests and applications.
◆Can Manufacturing◆
There are not many factories that can make large cans. We can handle complex shapes such as corrosion and heat resistant stainless-steel housings, truss shapes (triangular aggregate shapes), honeycomb shapes (hexagonal aggregate shapes) and round shapes, which are often used for medical and health care equipment.
◆One-stop Service◆
We have established an integrated production system from design to in-house assembly. Therefore, we provide one-stop service from order to delivery. We can provide total solutions for manufacturing, ensuring thorough quality control in all processes and manufacturing products at low costs.
◆Assembly/Welding◆
Product assembly and wiring assembly are done at the Haruna Plant.
◆Ready-To-Go◆
In the increasingly globalized world, we respond to our customer's requests in a precise and flexible manner. We respond immediately from the initial stages, including proposals from the planning stage and participation in the design process. We also respond immediately to requests for prototyping, strength analysis, and performance testing.
◆Product Development◆
We are working on new product development based on the technology we have cultivated over many years.
Most recent update:2024-05-22
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Mirror surface machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Laser and turret punch press processing Laser processing (longer than 121.2 m) CO2 laser machining Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Precision cutting Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Robot welding Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Blanking die Progressive die Single press die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Bending Blanking Roll forming Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Transfer press (80 - 200 t) Transfer press (200 - 500 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Sheet-metal processing | Can-making Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Angle processing 3-roll machine Bender processing (flood control) Bender processing (servo) Bending process |
Mass production | Blank cutting | Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum Precision cutting |
Surface treatment | Coating | Powder coating Melamine coating Acrylic coating Metal coating |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Parts manufacturing | Other parts | Sign board manufacturing |
Product manufacturing | Production property | Carrier machine manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing Construction and civil engineering material manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
