TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Company name |
株式会社 ダイヤテック (Daiyatekku) |
Website URL | |
Street address |
Wakayama Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 16 |
Annual sales | Unregister | EMIDAS Member Number | 104608 |
Type of manufacturing | Office automation equipment / Telecommunication equipment / Electrical component for transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Tapping Iron Stainless steel |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Precision cutting Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding YAG laser machining |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Sheet-metal processing | Can-making Air conditioning equipment manufacturing Kitchen equipment manufacturing NC set press Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Bender processing (over 3.0m) Angle processing Deburring process Painting process Hairline processing 3-roll machine Bender processing (flood control) Bender processing (servo) Bending process |
Mass production | Blank cutting | YAG laser processing Turret punch punching Shirring Cutting process Laser and turret punch punching Laser processing (over 1.2m) Connor Shah CO2 laser processing Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum Precision cutting |
Mass production | Welding / welding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding YAG laser processing |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Measuring |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Cardboard box manufacturing Food industry machinery manufacturing Coating equipment manufacturing Industrial furnace/Test furnace manufacturing Industrial robot manufacturing Information equipment manufacturing Monitoring device manufacturing Environmental equipment manufacturing Semiconductor manufacturing equipment manufacturing LCD manufacturing |
