We are a trading company with an office in Thailand.
Our motto is “We will do anything".
PR message
SHOEI TRADING (THAILAND) delivers top-quality industrial and automotive products with unmatched reliability and superior service.
The high-performance hydrocarbon-based cleaning agent "NS Clean" was developed based on the concept of "for people and the environment of the earth" and has been highly evaluated in many industrial fields as a cleaning agent friendly to the natural and working environments.
"NS Clean" has achieved both dryness and safety by realizing an extremely narrow boiling point range in addition to excellent cleaning performance. Moreover, it is not subject to environmental regulations such as the PRTR Law and the Ordinance on Prevention of Organic Solvent Poisoning. It has been well received in a wide range of cleaning fields, mainly for degreasing and electrolytic cleaning of metal parts in general. In addition, it has a high recovery rate through distillation and regeneration, and demonstrates stable performance even under continuous regeneration.
Hydrocarbon Cleaning Agents
NS Clean 100 (Class 2 Petroleum)
Boiling point: 171°C
Flash point: 51°C
Cleaning of processing oils
In addition to its excellent cleaning performance, NS Clean has a very narrow boiling point range, making it both dry and safe, and it is not subject to environmental regulations such as the PRTR Law and the Ordinance on Prevention of Organic Solvent Poisoning. It has been well received in a wide range of cleaning fields, centering on degreasing cleaning of metal parts in general.
Applications
Cleaning of mineral processing oils
It has been widely used as an alternative cleaning agent to chlorinated and brominated solvents.
Features
1. Excellent cleaning performance
Demonstrates excellent cleaning effects in a short time
2. Shortening of working time due to its excellent drying property
Narrow boiling point range and excellent drying performance shorten working time.
3. Recyclability
Stable quality can be maintained with little loss even after repeated distillation and regeneration.
Easy liquid control as quality remains unchanged through distillation and regeneration.
4. Long life for continuous regeneration
Chemically and thermally stable material with a long service life
Can be used safely for continuous regeneration by reduced-pressure steam cleaning and reduced-pressure distillation/regeneration
Regulations
PRTR Law: Not applicable
Ordinance on Prevention of Organic Solvent Poisoning: Not applicable
NS Clean 200 (Class III petroleum)
Boiling point: 191-207°C
Flash point: 70°C
Applications
Features
3. Recyclability
Regulations
Hydrocarbon-based cleaning agent NS CLEAN 100W
NS CLEAN is a cleaning agent containing a special surfactant in NS CLEAN.
The surfactant provides the following excellent performance.
Water displacement performance
Quickly draws away water adhering to the object to be cleaned.
Separated water becomes water droplets which settle quickly due to the difference in specific gravity.
Effective for removing water after water-cleaning of water-soluble stains (e.g. water-soluble cutting oil) and after wet barrel polishing.
Fine particle removal performance
Quickly separates inorganic particulates (metals, ceramics) adhering to the object being cleaned into the liquid.
Effective for removing abrasive particles, swarf, etc.
Typical properties
Appearance: pale yellow transparent
Density (15°C, g/c㎥): 0.737
Flash point (°C): 52
Fire Services Act (Hazardous material Class 4): Petroleum No. 2
Industrial Safety and Health Law (Organic Solvent Poisoning Prevention Law): Not applicable
Revised Air Pollution Control Law Hazardous Air Pollutants : Not applicable
VOC Regulations: Not applicable
Points to note when using
After using NS CLEAN W type, it is necessary to rinse with NS CLEAN.
Use a simple metallic tank or explosion-proof cleaner as the liquid is flammable.
Use at room temperature with good ventilation.
The high-performance hydrocarbon-based cleaning agent NS Clean was developed based on the concept of ‘for people and the environment’ and is highly regarded in many industrial fields as a cleaning agent friendly to the natural environment and the working environment.
In addition to its excellent cleaning performance, NS Clean has an extremely narrow boiling point range, making it both dry and safe. Moreover, it is not subject to environmental regulations such as the PRTR Law and the Ordinance on the Prevention of Organic Solvent Poisoning. It has been well received in a wide range of cleaning fields, particularly in the degreasing and electrolysis of metal parts in general. It also has a high recovery rate through distillation and regeneration, and demonstrates stable performance even under continuous regeneration use.
Paraffin
Normal paraffin
Hydrocarbon-based cleaning agent NS CLEAN 220W
Quickly draws away water adhering to the object being cleaned.
Typical properties
Density (15°C, g/c㎥): 0.756
Flash point (°C): 81
Fire Services Act (Hazardous material Class 4): Petroleum No. 3
Revised Air Pollution Control Law Hazardous Air Pollutants: Not applicable
Paraffin
Normal paraffin
Type R includes mineral oils as well as vegetable processing oils and rosin-based solder fluxes. It has excellent cleaning properties for a wide range of contaminants.
Like NS Clean (standard type), which is ideal for cleaning mineral-based processing oils, it contributes to the substitution of chlorinated solvents by customers as an environmentally-friendly cleaning agent.
It is a highly effective cleaner for a wide range of contaminants in a short period of time.
Features.
The cleaning power (solubility) for various contaminants has been improved while utilising the excellent characteristics of NS Clean.
1. high cleaning power comparable to that of chlorinated solvents.
2. as with NS Clean 100, it has excellent drying properties.
3. Narrow boiling point range and excellent distillation and regeneration properties.
4. excellent chemical and thermal stability and can be used in vacuum distillation cleaning systems.
5. non-corrosive to metals and has little effect on many synthetic resins.
Typical properties
Appearance: Colourless and transparent
Density: 0.780 (15℃、g/c㎥)
Distillation properties
Initial boiling point : 166 (℃)
End point : 176 (℃)
Kinematic viscosity : 1.34 (20℃、m㎥/s)
Aniline point :59 (℃)
SP value :7.9 ([cal/ml]1/2)
Chlorine content : Less than 1 (wtppm)
Flash point :51 (℃)
Fire Service Law Classification: Hazardous material Class 4, Petroleum No. 2
Occupational Health and Safety Law Not applicable
PRTR Law Not applicable
Air Pollution Control Law Hazardous Air Pollutant Not applicable
VOC Regulation Not applicable
Thailand
Bangkok
Features.
Typical properties
Density: 0.861 (15℃、g/c㎥)
Initial boiling point : 188 (℃)
End point : 226 (℃)
Flash point :73 (℃)
Fire Service Law Classification: Hazardous material Class 4, Petroleum No. 3
Thailand
Bangkok
Company name | SHOEI TRADING (THAILAND) CO., LTD. | Website URL | |
Street address |
Huai Khwang District Bangkok Kingdom of Thailand
[See map] |
Person in charge | Masatoshi Iwashiro |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 110,000,000 THB | Employees | 11 |
Annual sales | Unregister | EMIDAS Member Number | 104597 |
Type of manufacturing | Industrial machinery | ||
Main 3 products |
