PR message
The leading electrical equipment distributor in Vietnam, specializing in wholesale supply to electrical stores nationwide, has participated in providing electrical supplies for key electrical projects throughout the territory of Vietnam.
Unscreened control cable 0.5mm2x4c
Brand : Dusonc
Made in : South Korea
There certificate of origin CO – CQ clear
Korean rubber cable
Samwon rubber cable imported genuine from Korea, with C/O documents, Test Report.
Specializing in trading all kinds of electric cables, welding cables, control cables,... soft rubber sheath, 99.9% pure copper.
Goods available, same day delivery. Have complete CO/CQ documents.
Quan Pham also provides specialized rubber hoist cables (hoist cables) used for less than 10 floors and less than 20 floors.
Clip rubber cable roller 3×70 + 1x35mm Samwon: https://youtu.be/a5qEisg3qI4
Technical characteristics of industrial plug sockets
– The plug socket is good for use in temperatures from - 25°C-80°C
– The plug can be used continuously for 1 hour at a temperature of 100°C
– Cheap industrial plug sockets are made from POLYAMIDE 6 material that is resistant to corrosion, fire, chemicals, and high pressure.
Harmonic filter
Reactor, also known as three-phase harmonic filters – effective RTR
Factory production: RTR Energia, S.L. – Spain
Origin: Madrid – Spain.
Production standards: IEC 60 831 – 1/2
EN 60 831 – 1/2
Commodity certificates: certificate of origin (C.O), quality certificates (C.Q), UL certification, ER, IQNET.
Use cable trays when using wires with thin protective coverings, or in outdoor environments. You should also choose the color that matches the cable type:
Orange cable trays are often used for control cables.
Gray cable trays are often used for electric cables.
Use cable ladders when using shielded wires such as XLPE or in basements, server rooms, or places with good environmental conditions.
Quan Pham Company always innovates according to the development of technology in absorbing new initiatives, always giving customers the best and safest service.
The Cosse head is a tool used for the electrical and industrial electrical industry. The main function of the Cosse head is to increase the contact between the conductor and the device, reducing short circuit incidents that cause fires and explosions. At the same time, the Cosse head increases the connection between the conductors. and the device does not fall off during use while also protecting the wire tip from environmental oxidation
Quan Pham specializes in distributing all kinds of cosse heads for domestic and foreign infrastructure investment projects, electricity, telecommunications, oil and gas, seaports, etc.
Product
+ Cosse head, Copper connecting pipe
+ Cosse head, aluminum and aluminum copper connection tube
+ C clamp, branch clamp - copper and aluminum
+ Grounding stakes and grounding boards, lightning protection accessories
+ Cable positioning clamp, cable support clamp, cable stopping clamp
+ Flexible bridge, copper cable
Quan Pham has extensive experience in selecting low voltage electrical equipment and accessories, and is widely used in power transmission and distribution grids, in power companies, in industrial parks and in industrial parks. high technology…
Company name | QUAN PHAM ELECTRICAL EQUIPMENT INDUSTRY COMPANY LIMITED | Website URL | |
Street address |
HO CHI MINH Ho Chi Minh Socialist Republic of Vietnam
[See map] |
Person in charge | |
Telephone number | +84-913717067 | Fax number | |
Capital | 29,000,000,000 VND | Employees | 50 |
Annual sales | Unregister | EMIDAS Member Number | 104552 |
Type of manufacturing | Jigs and tools | ||
Main 3 products |
