The KF series is compatible with cleaning liquids with special properties. It absorbs even the smallest foreign matter and can be used for a long time.
The KF series is a filter that effectively absorbs and removes foreign substances from liquids using multilayer fibers with various absorbent properties. This fiber has the ability to capture and remove foreign objects even of very small size. Additionally, the long cycle time until filter saturation allows for long-term use. It can be used with aqueous or non-aqueous liquids and is particularly effective in situations where electroseparative oil cleaners are difficult to apply, such as oils with high water content or oils with unique properties.
Features
Multi-layer fiber structure: Multi-layer fibers with different absorption properties effectively trap microscopic foreign particles.
Long-term use: It takes a long time for the filter to become saturated, contributing to reduced maintenance frequency.
Compatible with a variety of liquids: Compatible with aqueous and non-aqueous liquids, and is also suitable for cleaning liquids with special properties.
specification
Absorbent fiber: Uses multilayer fibers with different absorbency.
Target substances: fine foreign matter, oil containing water, liquids with special properties.
Applicable liquids: aqueous liquids and non-aqueous liquids.
The KF series has a high cleaning effect even on liquids with special properties, can be used for a long period of time, and is indispensable for maintaining the quality of liquids. It is expected to be used in a wide range of fields due to its ability to remove minute foreign matter and low maintenance.
Company name | TSUBACO KTE CO.,LTD. | EMIDAS Member Number | 104370 |
Country | Kingdom of Thailand | Street address |
BANGRAK Bangkok Kingdom of Thailand |
Telephone number | 02-632-9466 | Fax number | 02-632-9470-1 |
Employees | 15,000,000 THB | Annual sales | |
Employees | Person in charge | Mr Akira Yuminaga |
