The Workresa WRM dust collector workbench allows you to efficiently perform a variety of tasks, from air blowing to polishing, with just one workbench.
Workresa WRM is a dust collector with a workbench dedicated to air blow work to blow away cutting dust generated from parts processed by machine tools. This all-in-one design makes efficient use of space in the processing shop and improves work efficiency.
Features
Simple vibration dust removal method: Dust is effectively removed by simple vibration.
Equipped with an air coupler: Air tools are easy to use and work efficiency is further improved.
Power tool compatible workbench: Parts can be machined on the workbench.
Adjustable opening: The desk type has an adjustable rubber seat that allows you to adjust the opening to small, medium, or large.
specification
Application: Air blow work, router work, polishing work
Features: Air coupler, power tool usable, opening adjustment function
Design: integrated workbench, vibration dust removal method
Company name | TSUBACO KTE CO.,LTD. | EMIDAS Member Number | 104370 |
Country | Kingdom of Thailand | Street address |
BANGRAK Bangkok Kingdom of Thailand |
Telephone number | 02-632-9466 | Fax number | 02-632-9470-1 |
Employees | 15,000,000 THB | Annual sales | |
Employees | Person in charge | Mr Akira Yuminaga |
