The other
ARGO WELLTECH
A Grinding Wheel is an essential tool for cutting, grinding, and shaping materials to achieve the desired form. There are various types of grinding wheels, and selecting the right one ensures optimal performance and durability.
1. Choose the Grinding Wheel Based on the Workpiece Material
The type of material you are grinding determines the abrasive grain you should use:
- General Steel / Carbon Steel → Use Aluminum Oxide (A)
- Hard Materials (e.g., Carbide, Hardened Steel) → Use Diamond or CBN
- Stainless Steel / Aluminum / Brass → Use Silicon Carbide (C)
- Glass / Ceramics / Marble → Use Diamond
✅ Choosing the correct abrasive type improves grinding efficiency and extends the wheel's lifespan.
2. Select the Grit Size Based on the Desired Finish
- Coarse Grit (24-60) → Fast material removal, suitable for rough grinding.
- Medium Grit (80-150) → General-purpose grinding.
- Fine Grit (180 and above) → Precision grinding, smooth surface finish.
✅ For a smoother finish, use a finer grit size.
3. Choose the Hardness of the Grinding Wheel
- Hard Grinding Wheel → Best for soft materials like aluminum.
- Soft Grinding Wheel → Best for hard materials like hardened steel.
✅ Choosing the wrong hardness can cause the wheel to wear out too quickly or reduce grinding efficiency.
4. Select the Right Bond Type
- Vitrified Bond (V) → Strong and rigid, suitable for general grinding.
- Resinoid Bond (B) → Flexible and ideal for high-speed grinding.
- Metal Bond (M) → Extremely durable, used for diamond and CBN grinding wheels.
✅ The bonding material affects the wheel’s lifespan and grinding performance.
5. Choose the Right Wheel Shape for Your Application
- Straight Wheel → Used for general-purpose grinding machines.
- Cup Wheel → Used for tool sharpening.
- Dish Wheel → Used for drill bit sharpening.
✅ Selecting the wrong shape may result in inefficient grinding and inconvenience during use.
For more details, download the PDF or contact us for further inquiries!
Company name | ARGO WELLTECH CO., LTD. | EMIDAS Member Number | 103712 |
Country | Kingdom of Thailand | Street address |
Klongton Nua,Wattana Bangkok Kingdom of Thailand |
Telephone number | +66-2-714-1511-4 | Fax number | +66-2-714-1561-2 |
Employees | 4,000,000 THB | Annual sales | |
Employees | 8 | Person in charge | Ms.Ratchanee (Sales Executive) |
Type of manufacturing | Machine tools / Industrial machinery | ||
