LCD/Plasma TV
Office automation equipment
Telecommunication equipment
The Ceramic Guide is a high-hardness solution designed to ensure precision in processing fibers, magnet wires, and cables. With outstanding wear resistance, it significantly reduces the frequency of part replacements.
Guide components in wire processing are crucial factors that directly impact production efficiency and product quality. Our Ceramic Guide is crafted from high-hardness ceramic materials, offering exceptional resistance to wear and corrosion. It is particularly suited for industries dealing with fibers, magnet wires, and cables, ensuring smooth movement and precise processing, leading to reduced production costs and consistently improved product quality.
Argo Welltech, based in Bangkok, provides comprehensive services across Thailand, responding promptly to regional needs.
■ Features
・High-Hardness Ceramic Material: Superior wear resistance compared to metal or plastic for long-lasting durability.
・Smooth Polished Surface: Minimizes wire friction for enhanced efficiency.
・Corrosion Resistance: Operates effectively in high-corrosion environments.
・Reduced Part Replacement Frequency: High durability minimizes the need for frequent replacements.
・Applications: Ideal for fiber, magnet wire, and cable industries.
■ Specifications
・Material: High-hardness ceramics such as alumina and zirconia.
・Durability: Up to 5 times more durable than metal guides.
・Precision Manufacturing: Designed and produced with micron-level accuracy.
・Polishing: Ultra-smooth surface with a finish of 0.1 micrometers or less.
■ Applications
・Fiber Industry: Serves as a guide for fibers, ensuring smooth movement and consistent tension.
・Magnet Wire Processing: Prevents wire damage and creates uniform coils.
・Cable Production: Enhances product quality stability with precision-guided systems.
High-hardness ceramic guides provide outstanding performance in wear resistance, corrosion resistance, and processing precision, boosting production efficiency and product quality.
Argo Welltech is ready to serve customers across Thailand, offering reliable and high-quality products.
For more information, download the PDF file or contact us directly!
Company name | ARGO WELLTECH CO., LTD. | EMIDAS Member Number | 103712 |
Country | Kingdom of Thailand | Street address |
Klongton Nua,Wattana Bangkok Kingdom of Thailand |
Telephone number | +66-2-714-1511-4 | Fax number | +66-2-714-1561-2 |
Employees | 4,000,000 THB | Annual sales | |
Employees | 8 | Person in charge | Ms.Ratchanee (Sales Executive) |
Type of manufacturing | Machine tools / Industrial machinery |
