【MODEL】
NK-FJS-A/ Straight tube
NK-FJP-A/ Helical tube
Male threaded type Fluorine resin hose
【USE】
Adjustment of piping, Lateral deflection, for chemical liquid *Do not torque the hose.
【FEATURE】
Both end is fluorine resin flexible section in the male thread.
Applicable fluid: Air, Water, Chemical fluid
*Limited to a fluid that does not pass through the fluorine resin.
Standard: JIS, ANSI, DIN
Nominal DIA 6~50
Length: 250mm~10M
Operating temperature: -50〜180℃
Operating pressure: 0.1~1.0MPa
【MATERIALS】
~NK-FJS-A/ Straight tube~
Nipple Carbon steel, Stainless Steel
Ring Stainless Steel
Tube PTFE
Braid Stainless Steel
Guard Spring Stainless Steel
~NK-FJP-A/ Helical tube~
Tube PTFE
【CONTACT】
Please make a call 072-874-0777 to EMIDAS representative in NFK.
Company name | Nangoku Flexible Hose Industry Co., Ltd. | EMIDAS Member Number | 103683 |
Daito City Osaka Japan |
Telephone number | +81-72-874-0777 | Fax number | +81-72-874-0786 |
Employees | 50,000,000 JPY | Annual sales | |
Employees | 140 | Person in charge | 宮本 健次 |
Type of manufacturing | Heavy electric machinery / Machine tools / Industrial machinery | ||
Primary clients |
