USE【MODEL】
NK-FJS-F/ Straight tube.
NK-FJP-F/ Helical tube.
NK-FJIS-F/ Insert tube.
【USE】
Adjustment of piping, Lateral deflection, for chemical liquid
*Do not torque the hose.
【FEATURE】
Both end is fluorine resin wetted parts with floating flange.
Applicable fluid: Air, Water, Chemical fluid
*Limited to a fluid that does not pass through the fluorine resin.
Standard: JIS, JPI, ANSI, DIN *Available for other dimensions.
Nominal DIA 15~100
*Please contact us for Nominal Diameter.
Length: 250mm~6M
*Please contact us about the length.
Operating temperature: -50〜180℃
Operating pressure: 0.1~1.0MPa
【MATERIALS】
~NK-FJS-F / Straight tube~
Flange Carbon steel, Stainless Steel
Stub End Stainless Steel
Tube PTFE
Braid Stainless Steel
Guard Spring Carbon steel, Stainless Steel
Ring Stainless Steel
Back-up Gasket Non Asbestos
~NK-FJP-F / Helical tube~
FL Fitting Stainless Steel
Tube PTFE
~NK-FJIS-F / Insert tube.~
Flexible Tube Stainless Steel
Collar Stainless Steel
Flange Stainless Steel
Inner Tube PTFE
[CONTACT]
Please make a call 072-874-0777 to EMIDAS representative in NFK.
Company name | Nangoku Flexible Hose Industry Co., Ltd. | EMIDAS Member Number | 103683 |
Daito City Osaka Japan |
Telephone number | +81-72-874-0777 | Fax number | +81-72-874-0786 |
Employees | 50,000,000 JPY | Annual sales | |
Employees | 140 | Person in charge | 宮本 健次 |
Type of manufacturing | Heavy electric machinery / Machine tools / Industrial machinery | ||
Primary clients |
