We are a manufacturer of automotive and industrial equipment parts with headquarters and second factory in Soja City, Okayama Prefecture, and an overseas factory in Chonburi, Thailand.
We have established an integrated production system that covers everything from machining to heat treatment, welding, and assembly.
PR message
We are an automotive and industrial equipment parts manufacturer with headquarters and second factory in Soja, Okayama Prefecture.
We also have overseas factory in Chonburi, Thailand.
In the automotive field, we mainly handle engine and transmission parts.
In the industrial equipment field, we handle air conditioning equipment parts, and have established an integrated production system from machining to heat treatment, welding, and assembly.
By designing and manufacturing our own processing jigs, pressure testing equipment, and inspection equipment, we have achieved optimal construction methods, short delivery times, and cost reductions.
We support the heart of manufacturing, which Japan is proud of around the world, with processing technologies such as environmentally friendly semi-dry processing, accumulator processing that requires high precision, and difficult involute curve processing, as well as a comprehensive quality control system using image processing and 3D measuring machines in a temperature-controlled room.
[Product Introduction]
●Automotive parts
・Input shaft
https://en.nc-net.or.jp/company/103665/product/detail/218232/
・Oil pump dummy cover assembly for medium-sized vehicles
https://en.nc-net.or.jp/company/103665/product/detail/218233/
・Oil pump dummy cover assembly for light to small vehicles
https://en.nc-net.or.jp/company/103665/product/detail/218234/
・Hub turbine
https://en.nc-net.or.jp/company/103665/product/detail/218251/
・Bearing cap assembly
・Pinion shaft
・Connector assembly
・Ball stud
・Accessory bracket
・Accumulator body
https://en.nc-net.or.jp/company/103665/product/detail/218252/
・Housing spindle
・Roll stopper bracket
●Compressor parts
・Movable scroll & fixed scroll
https://en.nc-net.or.jp/company/103665/product/detail/218239/
https://en.nc-net.or.jp/company/103665/product/detail/218250/
・Oldham's coupling
●Oil machine parts
・End cap & center section
・Housing
[Production equipment]
NC lathes, NC lathe combination machines: 166 units
Machining centers: 213 units
Grinding machines: 30 units
Rolling machines, broaching machines: 13 units
Hobbing machines, gear shapers: 6 units
Other machining equipment: 88 units
Assembly and pressure testing equipment: 66 units
High-frequency hardening equipment: 5 units
Washing machines: 45 units
Ultra-high-pressure washing machines: 10 units
Robots, loaders, etc.: 108 units
Welding machines: 7 units
Other equipment: 44 units
[Major quality assurance equipment]
3D measuring machines: 5 units
Contour shape measuring machines, roundness measuring machines: 4 units
Surface roughness measuring machines: 6 units
Cleanliness measuring equipment: 1 unit
In-line precision inspection equipment: 53 units
Image processing inspection equipment: 6 units
Magnetic flaw detectors: 3 units
Various hardness testers: 6 units
Metaloscopes: 2 units
Servohydraulic testing machine: 1 unit
Pressure testing machine: 1 unit
Click here to download the company information and PDF documents(Japanese only)
https://www.nc-net.or.jp/company/103665/dl/catalog/188455
・12 problem solving and improvement cases [including VA/VE proposal details]
・Company information pamphlet
We look forward to your technical consultations and quotation requests!
Please do not hesitate to contact us about costs, delivery times from prototypes to mass production, etc through inquiry page below↓
https://en.nc-net.or.jp/company/103665/inquiry/
SOJA INDUSTRY CO., LTD.
82-1 Ijirino, Soja City, Okayama Prefecture, 719-1154
TEL: +81-866-93-3621 FAX: +81-866-93-3625
Business Hours: 9:00-17:00 (Japan time)
Website: https://soja-industry.jp/
【Oil pump dummy cover assembly】
CVT parts for medium-sized vehicles.
Cold-forged shaft is pressed into the cast cover and numerous deep-hole oil hydraulic circuits.
This product become a pioneer in long drill processing.
Deep hole processing at ultra-high speeds is impressive.
We designed our own inspection devices to detect the presence of foreign substances (contamination) in hydraulic circuits dug deeply using long drills.
Other foundations of our line production may be found everywhere, including high-pressure washing for deburring, clean rooms to avoid contamination, pressure and completed dimension inspection equipment, and so on.
Oil pump dummy cover assembly manufacturing line video ↓
https://www.youtube.com/watch?v=B2w78jWEFzs
・Milling
・Lathe
・Ultra-high-speed semi-dry deep hole drilling
It drills a 180mm deep hole in one go with a φ6mm drill
・Shaft press-fitting
・External diameter grinding
Oil pump dummy cover assembly oil passage pressure inspection machine line video ↓
https://www.youtube.com/watch?v=8ArAOmj36nc
・High pressure leak inspection of hydraulic circuits
Oil pump dummy cover assembly oil passage contamination inspection machine line video ↓
https://www.youtube.com/watch?v=1DYPgRfCJNs
・Checking the inside of deep holes
See other introduction from below links(in Japanese)
※Deep hole long drill processing↓
https://www.nc-net.or.jp/company/103665/product/detail/225061/
※Inspection machine using medical endoscope↓
https://www.nc-net.or.jp/company/103665/product/detail/225062/
※Circuit hole pressure inspection machine↓
https://www.nc-net.or.jp/company/103665/product/detail/225708/
[Our strengths (technical capabilities)]
We are an automotive and industrial equipment parts manufacturer with headquarters and second factory in Soja City, Okayama Prefecture, and an overseas factory in Chonburi, Thailand.
● With over 50 years of experience, we specialize in high-precision machining and integrated manufacturing, including heat treatment, welding, and assembly. We are also experts at high precision parts processing.
● We design our own processing jigs, pressure measuring equipment, and inspection equipment, resulting in shorter delivery times and lower costs through optimized production procedures.
【Click here to download PDF documents】(Japanese only) ↓
【Hub turbine】
An in-house built full-scale inspection equipment put in the automated line measures outer diameter, inner diameter, flatness, and hole location. The measurement findings are transmitted back into the machine for automated adjustment.
The adoption of this equipment enabled the line to be entirely automated.
Hub turbine inspection machine line video
・Automated line incorporating a full inspection machine
・Measurement results are fed back to the processing machine for automatic correction
※Automatic correction processing using a 2-spindle lathe and company made full inspection machine↓(in Japanese)
https://www.nc-net.or.jp/company/103665/product/detail/225707/
[Input shaft]
CVT parts for small vehicles.
The whole process, from material input to turning, rolling, finishing, and 100% inspection, is automated.
Special rolling dies are used to roll unique spline forms (various specifications).
To achieve accurate precision when controlling the outer diameter polishing dimensions, the first product after grinding stone dressing has an automated removal feature that detects dimensional abnormalities early.
We guarantee 100% main dimensions using our own in-house inspection machine.
*Special spline shape processing↓(in Japanese)
https://www.nc-net.or.jp/company/103665/product/detail/225065/
*100% company made inspection machine↓(in Japanese)
https://www.nc-net.or.jp/company/103665/product/detail/225066/
[Accumulator body]
Transmission part, cup-shaped casting automotive part.
The cylindricity and surface roughness of the thin-walled cylinder's inner diameter need extremely difficult processing, yet our unique processing technology has enabled mass manufacturing.
Furthermore, employing an in-house built 100% cylindricity inspection machine, we can ensure complete correctness.
Measurement results can be archived as graph data.
※Click here for details on internal diameter processing↓(in Japanese)
https://www.nc-net.or.jp/company/103665/product/detail/225064/
Accumulator body manufacturing line video ↓
https://www.youtube.com/watch?v=tRfJYG3CNXU
・Drilling
・Turning
・Internal diameter finishing
・Internal diameter cylindricity φ0.05, Internal diameter surface roughness Rz3.2
Accumulator body
Full-scale cylindricity inspection machine line video ↓
https://www.youtube.com/watch?v=YCpcv2dBlqA
・Measures inner diameter cylinder φ53 x depth 90, wall thickness 3, thin wall cylindricity φ0.05
・We displays the measured results in graphs
[Input shaft]
Long drilling and thin-wall rolling technologies are utilized to minimize the number of processes and cut costs.
Appearance inspections with image processing are now available in the final appearance room.
Furthermore, automated inspection equipment for main parts have been placed in-line to entirely eliminate the outflow of defective products.
While our company has many automated lines, this is one that purposefully requires manual removal and attachment. However, by fully using mechanisms, it is our quickest line, with workpiece removal and attachment speeds of less than 3 seconds each procedure.
See other introduction from below links(Japanese only)
*Deep hole long drill processing↓
https://www.nc-net.or.jp/company/103665/product/detail/224948/
*Thin wall rolling technology↓
https://www.nc-net.or.jp/company/103665/product/detail/224949/
*Reduction in manual work time↓
https://www.nc-net.or.jp/company/103665/product/detail/224956/
*Image processing appearance inspection↓
https://www.nc-net.or.jp/company/103665/product/detail/225026/
Input shaft manufacturing line video↓
https://www.youtube.com/watch?v=SHaO-zax9yA
・Semi-dry high-speed deep hole processing
・Workpiece discharge by mechanism improvement
・Our fastest 3 Second line
Input shaft image processing appearance inspection line video ↓
https://www.youtube.com/watch?v=Sr0lgQ7zunk
Input shaft automatic measuring machine line video ↓
・Automatic measuring machine
・Measure each part
・Automatic transport to a stocker in a clean room
[Oil pump dummy cover assembly]
CVT parts for light to small vehicles.
Aluminum die-cast cover, cold forged shaft pressed in to finishing.
A fully automated line, from material input to the visual inspection process.
One of our leading lines, bringing together all of our processing technology.
←See the video for the production line
・Automatic removal from the material box
・Fully automated with 26 loaders, cycle time 30 seconds
・Shaft turning
・Removal of cover material
・Cover hole drilling
・Automatic transfer to press-in machine
・Shaft pressing (press-in input control)
・Finishing turning
・Cleaning loader
・Deburring with ultra-high pressure washer
・Transport to clean room after air blow
・Fully automated after dimensional inspection, function inspection, and before appearance inspection
Relief valves (a combination of ball and spring) are pressed in at the same time, and their relief function is tested to ensure complete functionality.
It also includes a feature that employs image processing to identify blowhole problems within the relief valve press-in hole, and it is one of our most advanced functional inspection machines, having developed our own unique functional inspection system and requiring a year to put into actual use.
Relief valve press-in & function inspection machine line video ↓
https://www.youtube.com/watch?v=dzr8jOIwmhg
- Image processing to check for material defects inside the relief press-in hole
- Press-in ball + spring + ball at once
- Checking the function of the pressed-in relief valve (flow rate, pressure, operation timing)
- Hydraulic circuit leak inspection
[Fixed scroll]
Compressor part for commercial air conditioners.
Function: as a pair of movable and fixed scrolls.
(Click here for movable scrolls ↓)
A cast iron bush is pushed into the movable scroll.
The flange has a flatness of 10μ and the bush has an inner diameter cylinder of Φ5μ.
Deep groove machining of a spiral shape. Ultra-high speed machining is accomplished using equipment co-developed with the manufacturer and our own involute curve program.
[Movable scroll]
(Click below link to see more about Fixed scrolls ↓)
NC turning machining( Mass production / Mechanical processing ) |
Company name | SOJA INDUSTRY CO., LTD | Website URL | https://soja-industry.jp/ |
Street address |
Soja City Okayama Japan
[See map] |
Person in charge | 藤井 敦 |
Telephone number | +81-866-93-3621 | Fax number | +81-866-93-3625 |
Capital | 54,000,000 JPY | Employees | 149 |
Annual sales | 2,760,000,000 JPY | EMIDAS Member Number | 103665 |
Type of manufacturing | Industrial machinery / Transportation equipment | ||
Main 3 products |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Deep hole drilling Rolling Thread-cutting Iron Stainless steel Aluminum alloy Broaching Keyway milling Air chuck equipment Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Centerless grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | Mass production jig manufacturing |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Complex turning machining Rolling machining Iron Stainless Aluminum alloy Broaching machining Casting Ultra-thin High precision |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Centerless grinding |
Surface treatment | Heat treatment | High frequency quenching |
Assembly/Inspection | Assembly | Auto parts assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Forging Casting |
