Coating Services, Tools, Automotive, Main Office
PR message
We offer a wide range of services and products, including various types of coatings like PVD, CVD, and PACVD, under the BALINIT, BALIQ, and BALDIA series. These technologies are applied across multiple industries, including automotive, medical, energy, and more.
Specialized thin film solutions for the highly sensitive semiconductor industry
Oerlikon Balzers‘ tailored diamond-like coating (DLC) solutions such as BALINIT DYLYN, endow wafer contact tooling and positioning systems with beneficial properties including low friction, excellent adhesion, and high thermal conductivity, without contaminating sensitive semiconductor wafers.
The better a DLC coating meets individual requirements, the lower the total cost of ownership. Our capabilities and application expertise enable us to precisely tailor the properties of our DLC coatings to a customers’ specific demands. High hardness, a low coefficient of friction and excellent wear resistance help to significantly reduce particle formation and thus enable high yield manufacturing – a key factor, especially regarding smaller feature sizes. Guaranteed reproducible quality of the coated parts provides consistent process reliability.
Oerlikon Balzers specializes in the provision of tailored semiconductor coatings that satisfy the highly stringent needs of the semiconductor industry. Just one example amongst many such solutions: a completely new coating that is resistant to etching by fluorinated chemistries, for applications including wafer e-chucks, pedestals, etch kits, showerheads and vacuum pump components.
Oerlikon Balzers coatings and heat treatments for engineered components in the automotive industry, reduce fuel consumption, improve wear resistance and allow compacter design.
PVD coating solutions for automotive components:
■enable the realization of innovative power-train concepts that provide fuel and lubricant savings and reduce pollutant emissions;
■improve the wear resistance and service life of components, thereby lengthening service intervals and reducing the need for spare parts;
■permit compacter design and the use of lighter materials that reduce overall weight;
■reduce friction losses in the engine and so increase overall drive train efficiency.
BALINIT® coating for more productivity in die casting
The die casting industry constantly finds itself confronted with new challenges in terms of die-cast part tolerances and cycle times. The exceptionally hard, extremely erosion and wear-resistant coatings from Oerlikon Balzers are a significant factor when it comes to protecting the mould from soldering and premature fire cracks. Thanks to BALINIT, both maintenance costs and scrap are greatly reduced. Thus, the coating makes a valuable contribution to process-reliable die casting and ensures product quality and productivity.
BALINIT coatings protect die casting moulds, mould inserts and cores from premature wear. Depending on the complexity of the cast part and the alloy used, up to 280,000 shots can be achieved with one treatment.
BALINIT® coatings:
■Reduce soldering
■Retard fire cracks
■Reduce erosion
■Reduce abrasion
This lets you achieve:
■Less scrap
■Increased service life
■Reduced maintenance costs
■Lower demoulding forces
■Optimal surface quality
■The best cast-part quality
The benchmark for injection moulding and extrusion
Coated forming tools provide excellent protection against corrosion and reduce friction and wear. Forming tool surface plays a crucial role in injection and extrusion: the better the quality, the greater the productivity and efficiency of the manufacturing process.
You can reliably attain this objective with innovative BALINIT® and BALITHERM® wear protection solutions from Oerlikon Balzers–a global technology leader in hard coatings.
Coated forming tools offer you numerous advantages for plastics processing:
■Improved de-moulding attributes
■Greater production efficiency and reliability
■Scratch and wear protection of mirror-polished cavities
■Enhanced corrosion protection
■Adhesion prevention
◆High-quality coatings for cutting tools from Oerlikon Balzers
Whether through higher productivity, more reliable production or increased efficiency – wear protection coatings offer huge potential savings.
◆Cutting
Coated tools can tolerate significantly higher cutting speeds and feeds, reducing machining time and costs. Their outstanding wear resistance, moreover, significantly extends tool life.
High-speed cutting (HSC) and dry machining generate extremely high temperatures. Thanks to the outstanding thermal stability, hot hardness and oxidation resistance of the coating, the heat is dissipated through the chips, without adversely affecting the cutting edge.
Special coatings with low friction coefficients and a low tendency to adhere, facilitate the machining of hard-to-machine materials such as aluminium, titanium and magnesium alloys, and high-alloy steels.
We offer the ideal coating for your application, according to the material to be machined and processing step involved. Whether turning, milling, drilling, reaming, threading or gear cutting - our first rate coatings will make your production faster, more efficient, and more reliable.
◆Reconditioning
Re-sharpened and re-coated tools provide the same performance as new coated tools and, thus, significantly longer overall tool life.
Company name | Oerlikon (Thailand) Co., Ltd. | Website URL | https://www.oerlikon.com/balzers/th/en/ |
Street address |
Amatanakorn Industrial Estate Phase 4 700/538 M.6, T.Donhualoh, A.Muang Chonburi Kingdom of Thailand
[See map] |
Person in charge | Akira Amano |
Telephone number | +66-61-392-6164 | Fax number | |
Capital | 80,000,000 THB | Employees | Unregister |
Annual sales | Unregister | EMIDAS Member Number | 103482 |
Main 3 products |
