Machine tool
HONDA ELECTRONICS
Cut all kinds of materials precisely and efficiently with the "ZO-95 Ultrasonic Cutter".
"ZO-95 Ultrasonic Cutter" is a high-end model that revolutionizes cutting work using the power of ultrasonic waves. Adopts a newly developed ultrasonic transducer, allowing power switching in 3 stages (S-High/High/Normal). Work efficiency is greatly improved by using a foot switch and reducing the time required to change blades at hand.
■ Features
- Powerful cutting with a newly developed ultrasonic transducer.
- Three power modes can be selected: S-High, High, and Normal.
- Improving operability and speeding up work with a foot switch.
■ Specifications
- Frequency: 40kHz enables fine and accurate cutting.
- Power supply: AC adapter (input: 100-240 V AC, output: 12 V DC).
- Body dimensions: width 185 x depth 169 x height 55 mm, handpiece diameter 28 x length 150 mm (including blade).
- Weight: Body approx. 1.2 kg, handpiece approx. 350 g.
For more information, please download the PDF or feel free to contact us.
Company name | HONDA ELECTRONICS CO., LTD. | EMIDAS Member Number | 102421 |
Country | Kingdom of Thailand | Street address |
Room 11, 2 Jasmine Bldg.,12 Fl., Soi Sukhumvit 23 (Prasanmitr),Sukhumvit Rd., North Klongtoey, Wattana Bangkok Kingdom of Thailand |
Telephone number | +66-2-612-7311 | Fax number | +66-2-612-7399 |
Employees | Annual sales | ||
Employees | 230 | Person in charge | Tetsuya Oyama |
