Industrial machinery
HONDA ELECTRONICS
【WDX oscillator】
Product Features
Our unique "Dyna-Shock Modulation (DM)" method by full digital technology enables full-range cleaning, from gentle to powerful, and provides the optimum cleaning effect for each application.
What is the Dyna Shock Modulation (DM) ?
The DM (DYNASHOCK MODULATION) is an oscillation method to obtain optimal cleaning effect for both gentle and powerful cleaning by controlling the ratio (modulation) of ultrasonic power generated simultaneously by two frequencies from the same transducer while the total output power remains constant.
By adjusting the ultrasonic power ratio between a low-frequency component suitable for powerful cleaning and a high-frequency component suitable for precision cleaning with low damage, optimal cleaning effects can be obtained according to the cleaning purpose, from powerful cleaning to precision cleaning.
In the WDX series, the ultrasonic power ratio of the two frequencies is called DM modulation. When the ultrasonic power of the low-frequency component is PL and the ultrasonic power of the high-frequency component is PH, it is defined as DM modulation degree = PL÷PH.
【WDX tank type】
■Accessories: Lid
●Liquid temperature range: 5 to 100°C
●Transducer: Bolt-clamped Langevin type transducer
●Transducer cable length: 3.5 m
●Optional accessory: Cleaning basket (KG10F, KG11T)
Company name | HONDA ELECTRONICS CO., LTD. | EMIDAS Member Number | 102421 |
Country | Kingdom of Thailand | Street address |
Room 11, 2 Jasmine Bldg.,12 Fl., Soi Sukhumvit 23 (Prasanmitr),Sukhumvit Rd., North Klongtoey, Wattana Bangkok Kingdom of Thailand |
Telephone number | 02-612-7311 | Fax number | 02-612-7399 |
Employees | Annual sales | ||
Employees | 230 | Person in charge | Tetsuya Oyama |
