PR message
Our company can provide industrial services related to ultrasonic tools such as ultrasonic cleaning machines, ultrasonic measuring machines, ultrasonic cutting machines, inspection machines (non-destructive), scratch or defect analysis tools and other industrial tools both in Thailand and the ASEAN region!
Cut all kinds of materials precisely and efficiently with the "ZO-95 Ultrasonic Cutter".
"ZO-95 Ultrasonic Cutter" is a high-end model that revolutionizes cutting work using the power of ultrasonic waves. Adopts a newly developed ultrasonic transducer, allowing power switching in 3 stages (S-High/High/Normal). Work efficiency is greatly improved by using a foot switch and reducing the time required to change blades at hand.
■ Features
- Powerful cutting with a newly developed ultrasonic transducer.
- Three power modes can be selected: S-High, High, and Normal.
- Improving operability and speeding up work with a foot switch.
■ Specifications
- Frequency: 40kHz enables fine and accurate cutting.
- Power supply: AC adapter (input: 100-240 V AC, output: 12 V DC).
- Body dimensions: width 185 x depth 169 x height 55 mm, handpiece diameter 28 x length 150 mm (including blade).
- Weight: Body approx. 1.2 kg, handpiece approx. 350 g.
For more information, please download the PDF or feel free to contact us.
The "ZO-91 Ultrasonic Cutter" is a standard model ideal for cutting operations on plastics, small items, parts for gate cutting and deburring, model cutting, and cutting films, sheets, and fabrics. It features the new TAF™ circuit, providing additional power when cutting becomes challenging. Its user-friendly design allows for the selection between Normal and High modes.
■ Features
- The new TAF™ circuit ensures stable performance even in difficult cutting conditions.
- Offers a choice between Normal and High modes to meet user needs.
- The handpiece is designed to be lightweight and easy to carry.
■ Specifications
- Frequency: Vibrations at 40kHz allow for fine cutting.
- Power Supply: AC adapter (Input: 100-240 V AC, Output: 12 V DC).
- Dimensions: Width 173 x Depth 89 x Height 76 mm, handpiece diameter 32 x length 144 mm (including blade).
- Weight: Main unit approximately 300 g, handpiece approximately 70 g.
For more details, please download the PDF or feel free to contact us.
The HLF800 Series Ultrasonic Flowmeter is the latest measurement technology from Honda Electronics that improves operational efficiency and accuracy in water and wastewater treatment facilities.
■ Features
・Non-contact measurement: Minimizes the risk of equipment damage and reduces maintenance effort.
・High precision: The latest ultrasonic technology accurately captures minute changes in flow rate.
・Wide range of applicability: Can be used to measure the flow rate of fresh water, sewage, and even chemicals.
・User-friendly: Easy to install and operate, you can start using it right away.
・Long-term stability: High reliability and durability even under harsh usage conditions.
■ Specifications
・Measurement principle: Non-contact ultrasound technology
・Applicable pipe diameter: 50mm to 600mm
・Measurement range: 0.1m/s to 10m/s
・Accuracy: ±1%FS
・Output interface: 4-20mA, digital (RS-485), relay output
The HLF800 series ultrasonic flowmeter sets a new standard for flow management in water and wastewater treatment facilities. With its high measurement accuracy and wide applicability, it is expected to contribute to streamlining facility operations and reducing costs.
The HL2000 Ultrasonic Interface Level Meter is Honda Electronics' precision liquid level measurement technology that provides industry-leading quality control.
■ Features
・Non-contact measurement: Measurements can be performed safely without damaging the product or container.
・High-precision measurement: Captures even minute changes at the interface level and provides precise data.
・Wide applicability: Meets the needs of diverse industries such as chemicals, food, and environmental management.
・User-friendly: Easy operation and easy-to-read display make it easy to use on site.
・Durability and reliability: Maintains stable performance even in harsh industrial environments.
■ Specifications
・Measurement principle: Ultrasonic non-contact measurement
・Target substance: Liquid-liquid interface
・Applicable temperature range: -20℃ to 60℃
・Accuracy: ±1mm
Honda Electronics' HD1200 ultrasonic level meter is an industrial liquid level measurement device that uses the latest non-contact ultrasonic technology. The device enables highly accurate level measurement of all types of liquids and contributes to process control and optimization in a wide range of sectors, from manufacturing to water treatment and the chemical industry. The HD1200 is designed for ease of use and reliability, and provides advanced liquid level management.
■ Features
・Advanced non-contact ultrasonic technology: Accurately measures liquid level without physical interference and provides stable performance.
・Wide measurement range: It is highly versatile and can measure liquid levels in a variety of containers and environmental conditions.
・Easy operation and installation: User-friendly design allows for easy installation and quick operation.
・Long-term stable operation: High durability that can withstand harsh industrial environments, reducing maintenance and management effort.
・Suitable for various applications: Ideal for measuring various liquids such as water, chemicals, and food.
■ Specifications
・Model: HD1200
・Measurement method: Ultrasonic non-contact type
・Scope of application: Industrial liquid level measurement
・Measurement distance and accuracy: See product specifications
・Power requirements: See specifications for details
・External dimensions and weight: Based on product specifications
Honda Electronics' HD323 is a high-precision ultrasonic level meter for liquid level measurement in industrial applications. This device enables efficient and accurate liquid level control in a variety of industrial processes by measuring liquid levels without contact. With its high reliability and accuracy, the HD323 helps optimize liquid handling processes and contributes to process stability.
■ Features
・Non-contact ultrasonic measurement technology: Accurately measures liquid level without physically touching the liquid.
・Wide measurement range: Compatible with a wide measurement range from small tanks to large storage facilities.
・Easy installation and operation: No complicated settings are required, making it easy to install and operate.
・High durability and stability: Demonstrates high durability even in harsh industrial environments and provides stable measurements over long periods of time.
・Applicable to a variety of applications: Applicable to a variety of applications, such as water treatment facilities, chemical tanks, and the food and beverage industry.
■ Specifications
・Model: HD323
・Measurement distance: See product specifications
・Power requirements: AC or DC power supply (see specifications for details)
Honda Electronics' HD353-A ultrasonic level meter is a high-performance measurement tool for industrial liquid management. Utilizing non-contact ultrasonic technology, it precisely measures liquid levels and contributes to efficiency and optimization of all industrial processes. HD353-A is easy to install and operate, and provides long-term stable performance with high durability and reliability.
■ Features
・Non-contact ultrasonic technology: Accurate liquid level measurement without physically interfering with tanks and containers.
・Suitable for a wide range of applications: Suitable for use in industries that require a variety of liquid management, such as water treatment, chemicals, and food and beverage industries.
・User-friendly: Easy to install and intuitive to operate. Does not require many settings or adjustments.
・Long-term durability: Designed to withstand use in harsh industrial environments, it maintains stable measurement performance over long periods of time.
・High measurement accuracy: Highly accurate liquid level measurement is possible from small tanks to large storage facilities.
■ Specifications
・Model: HD353-A
Honda Electronics' W-357LM-80 running water ultrasonic cleaning machine is a high-frequency line type cleaning machine specialized for the semiconductor manufacturing industry. Cutting-edge semiconductor manufacturing processes require the removal of minute impurities. W-357LM-80 is a product developed to meet this high demand, contributing to improved semiconductor quality and production efficiency.
■ Features
・High-precision cleaning technology: High-precision cleaning using ultrasonic cleaning effectively removes minute dirt and impurities.
- Running water cleaning system: Continuous running water cleaning enables highly efficient cleaning and reduces production line downtime.
・Environmentally friendly: A cleaning liquid reuse system is adopted, contributing to the reduction of waste liquid and cost.
・User-friendly design: Adopts an intuitive control panel and easy maintenance design.
・High versatility and customizability: It is compatible with various semiconductor manufacturing processes and can be customized to meet customer needs.
■ Specifications
・Model: W-357LM-80
・Cleaning method: Running water ultrasonic cleaning
・Scope of application: Semiconductor manufacturing industry
・Power requirements: AC 100V to 240V, 50/60Hz
・External dimensions: Please refer to the product specifications for detailed dimensions.
・Operation interface: User-friendly touch panel
Company name | HONDA ELECTRONICS CO., LTD. | Website URL | https://www.honda-el.co.jp/ |
Street address |
Room 11, 2 Jasmine Bldg.,12 Fl., Soi Sukhumvit 23 (Prasanmitr),Sukhumvit Rd., North Klongtoey, Wattana Bangkok Kingdom of Thailand
[See map] |
Person in charge | Tetsuya Oyama |
Telephone number | +66-2-612-7311 | Fax number | +66-2-612-7399 |
Capital | Employees | 230 | |
Annual sales | Unregister | EMIDAS Member Number | 102421 |
Main 3 products |
