PR message
○ The first manufacturer in Thailand to receive the TIS 397-2562 standard.
○ Manufacturer of Spun Micro Pile endorsed by SCG as an endorsed brand.
○ Production of concrete and standardized raw materials.
○ SCG-CPAC Program.
○ Standard compliance with TIS for Micro Pile, TIS 396-2549.
Contractor 4U
Comprehensive answer to the complete extension work
Customers may face the problem of a remodeling contractor when considering home remodeling, kitchen remodeling, garage remodeling, or general construction work. Afraid that the work will not be completed or the contractor leaves the job, Phum Siam can help you to meet the needs of the complete extension work. One thing that Phum Siam Giving confidence to customers is always foundation service quality And always give advice to reliable contractors.
With more than 10 years of foundation work experience in the construction industry, we know the problems of our customers very well. to meet the needs of customers We have a group of quality contractors ready to recommend. for construction work or additional work for customers without charge to make the right choice With the addition work, whether small or large, by Phum Siam, we do not charge additional expenses from customers.
You can ask for free. Hotline. Recommend contractors. Call 063-889-7987.
Installation of Square Spun Micro Piles
Our services include consultation on foundation systems and the installation of square spun micro piles, following the standards set by the Ministry of Construction. We provide these services nationwide for various projects, including residential renovations, industrial facilities, buildings, and projects that require 100% safety assurance, such as the Phra Nakhon Si Ayutthaya Power Plant, petroleum refining facilities, petroleum depots, and gas stations operated by PTT.
Square Spun Micro Pile, Size 23x23 cm.
The cross-sectional dimensions are 23x23 cm. Each pile has a safe load capacity of 25-35 tons (depending on the soil conditions) and a length of 1.5 meters per section. The pile is equipped with a steel cap at the end for reinforcement. The Square Spun Micro Pile allows for the extension of its length (depth) by connecting additional square spun micro piles using the method of circumferential pile connection, thus increasing the depth as required until reaching the firm ground. The safe load capacity can be verified through Last 10 Blow Count or Dynamic Load Test methods.
- The first in Thailand to comply with the standards of the Ministry of Communications for Square Spun Micro Pile.
- The first spun micro pile manufacturing plant in Thailand.
- Endorsed Brand by SCG, ensuring quality.
- The first in Thailand to adopt computer systems.
- State-of-the-art production of Spun Micro Pile.
- Compressive strength values meet or exceed the requirements of the Ministry of Communications, with a minimum of 350 Cylinder strength and 400 Cube strength.
- Cold-rolled steel wires with a central diameter of 4 mm are spirally wrapped around the reinforcement at regular intervals.
- Longitudinal reinforcement (vertical bars) with a diameter of 6 mm, consisting of 8 bars.
- Produced and mixed with concrete using the same computer system program as SCG-CPAC.
(Dowel can be ordered according to customer's desired manufacturing sizes.)
Square Spun Micro Pile Size 18x18 cm.
With a cross-sectional size of 18x18 cm, the pile has the ability to safely support a weight load of 15-20 tons per pile (depending on the soil conditions). Each section has a length of 1.5 meters and is equipped with a tensioning rib at the end. The Square Spun Micro Pile allows for the extension of length (depth) by connecting additional sections of Square Spun Micro Pile using the method of circumferential pile-to-pile welding, thus increasing the depth as required until reaching the firm soil layer. The safe weight load capacity can be verified through the Last 10 Blow Count or Dynamic Load Test methods.
- The first in Thailand to meet the standard of the Ministry of Communications for Square Spun Micro Pile.
- The first manufacturing factory of Spun Micro Pile in Thailand.
- Endorsed Brand by SCG, guaranteeing quality.
- The first in Thailand to utilize advanced computer systems in Spun Micro Pile production.
- Compressive strength values meet or exceed the Ministry of Communications requirements, with a minimum of 350 cylinder strength and 400 cube strength.
- Cold-rolled spiral wire with a diameter of 4 mm, wrapped around the lengthwise reinforcement.
- Lengthwise reinforcement (Vertical Rebar) with a diameter of 6 mm, quantity: 4 pieces.
- Production and concrete mixing using the same computer system program as SCG-CPAC.
(Dowel can be custom ordered according to customer's production size requirements).
"Spun Micro Pile (Round Prestressed Concrete Pile) Dia 30 cm.
With a diameter of 30 cm, the pile has the ability to safely support a weight load of 30-50 tons per pile (depending on the soil conditions). Each section has a length of 1.5 meters and is equipped with a tensioning rib at the end. The Spun Micro Pile allows for the extension of length (depth) by connecting additional sections of Micro Pile using the method of circumferential pile-to-pile welding, thus increasing the depth as required until reaching the firm soil layer. The safe weight load capacity can be verified through the Last 10 Blow Count or Dynamic Load Test methods.
- The first in Thailand to meet the standard of the Ministry of Communications for Spun Micro Pile.
- Special reinforcement steel (Rebar) RB9, quantity: 10 pieces.
- Spiral casing: Cold-rolled spiral wire with a diameter of 4 mm.
- Lengthwise reinforcement (Vertical Rebar) RB9, quantity: 10 pieces.
- Plate joint: 6 mm thick steel plate.
- Collar: FB 2" with a thickness of 6 mm.
(Dowel can be custom ordered according to customer's steel size requirements).
Collar (Edge): FB 2"
- Standard: Collar thickness of 4 mm.
- Premium: Collar thickness of 6 mm."
Spun Micro Pile (Dia 25 cm)
The Spun Micro Pile has a diameter of 25 cm and is capable of safely bearing a weight of 25-35 tons per pile, depending on the soil conditions. Each section has a length of 1.5 meters and is reinforced with a tensioning rib at the rear end. The Spun Micro Pile can be extended in length (depth) as needed by connecting the sections using the circumferential splicing method to achieve the desired depth, reaching the underlying soil layer. The safe weight-bearing capacity can be verified using either the Last 10 Blow Count method or the Dynamic Load Test.
Key Features:
- First in Thailand to meet the standards set by the Ministry of Communications for Spun Micro Piles.
- First in Thailand to have a Spun Micro Pile manufacturing plant endorsed by SCG, ensuring quality.
- First in Thailand to utilize modern computer systems in the production of Spun Micro Piles.
- Concrete compression strength meets or exceeds the requirements of 350 cylinders and 400 cubes, as specified by the Ministry of Communications.
- Special reinforcement steel (comar) with 8 pieces of RB9.
- Spiral sleeve: Cold-drawn steel wire with a central diameter of 4 millimeters.
- Length-based reinforcement with 8 pieces of RB9.
- Plate joint: 6-millimeter thick steel plate.
- Collar: FB 2" with a thickness of 6 millimeters.
(Dowel can be custom ordered according to customer's steel specifications)
Collar (Collar) FB 2"
*Standard = Collar with a thickness of 4 millimeters.
*Premium = Collar with a thickness of 6 millimeters.
Spun Micro Pile (Dia 21 cm)
The Spun Micro Pile has a diameter of 21 cm and is capable of safely bearing a weight of 20-25 tons per pile, depending on the soil conditions. Each section has a length of 1.5 meters and is reinforced with a tensioning rib at the rear end. The Spun Micro Pile can be extended in length (depth) as needed by connecting the sections using the circumferential splicing method to achieve the desired depth, reaching the underlying soil layer. The safe weight-bearing capacity can be verified using either the Last 10 Blow Count method or the Dynamic Load Test.
Key Features:
- Special reinforcement steel (comar) with 6 pieces of RB9.
- Length-based reinforcement with 6 pieces of RB9.
Company name | Bhumisiam Supply Co.Ltd. | Website URL | https://www.bhumisiam.com/ |
Street address |
Bueng Thong Lang Subdistrict, Lam Luk Ka District Pathum Thani Kingdom of Thailand
[See map] |
Person in charge | Sun |
Telephone number | 064-056-8317 | Fax number | 02-156-9805 |
Capital | 69,000,000 THB | Employees | Unregister |
Annual sales | Unregister | EMIDAS Member Number | 101889 |
Main 3 products |
