Shogo Vietnam specializes in manufacturing electrical busbars and EV High-Voltage Cable wires used in the energy industry and especially in the Electric Car industry.
PR message
Shogo Vietnam Joint Stock Company is one of the pioneering companies in Vietnam to produce Busbar conductive busbars, HV Cable high voltage conductors used in green energy industries. Especially in the field of Electric Car manufacturing.
SHOGO Vietnam.,JSC is the No. 1 Busbar and Cable manufacturer in Vietnam for the new energy industry. We are committed to providing our customers with products of the highest quality standards. All raw materials are inspected for quality before production, and 100% of products are thoroughly inspected before delivery. SHOGO Vietnam holds prestigious certificates: IATF16949-2016, ISO 9001-2015, ISO 14001-2015, ISO/IEC 17025-2017,…
The Busbar is made of copper alloy with a copper ratio of > 99.95%. The outside can have a surface treatment layer of nickel (Ni), tin (Sn) or other alloys that create good corrosion resistance when working in acidic environments. Some Busbars are covered with PVC or PE to provide insulation when working in environments that require electrical safety.
Depending on customer requirements, Shogo can produce solid copper busbars or flexible busbars. Solid copper busbars are made from copper bars or shaped copper sheets, which has the advantage of being able to withstand its own weight and increase heat resistance when working. Flexible busbars are made by laminating many thin layers of copper foil and connecting them together, so they have the advantage of working well when expanded by working temperature, under impact when moving and in difficult areas. Difficulty in assembly.
EV High-Voltage Cable with Connector products are manufactured at Shogo with a variety of types. Used to connect the charging port and battery, inside the battery, battery and motor and other parts, as well as battery energy storage equipment and other fields, as a power carrier.
HV Cable on electric vehicles includes 3 main parts:
- Part 1: High voltage cables are often used with high performance and feature cables such as Shield cable (XLPE, XLPO...) or Unshield cable depending on the purpose and working environment.
- Part 2: The connection head (connector or terminal) has the main task of bridging between details and areas that need to transmit electricity.
- Part 3: Protective covers are often used pipes, tape, fabric... with insulating properties, fireproof, anti-corrosion, oil and chemical resistance...
CO2 laser machining ( Development and production of prototype/Small-scale production / Blank cutting ) |
Company name | SHOGO VIET NAM JOINT STOCK COMPANY | Website URL | https://shogobusbar.com |
Street address |
Van Lam Hung Yen Socialist Republic of Vietnam
[See map] |
Person in charge | Mr Bern |
Telephone number | +84-+84-393929885 | Fax number | 0 |
Capital | 50,000,000,000 VND | Employees | 200 |
Annual sales | 200,000,000,000 VND | EMIDAS Member Number | 101731 |
Type of manufacturing | Heavy electric machinery / Jigs and tools / Electrical component for transportation equipment | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Designing | Product and part designing | External design |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Industrial equipment designing | Plant equipment designing |
Material | Specialized material distribution | Phosphor bronze Tin/Zinc based alloy |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) Iron Aluminum alloy Handles microfabrication Brass |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing Bending (over 3.0 m) Deburring Hair line machining Swaging |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Laser and turret punch press processing Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Laser marking Microfabrication (laser machining ) Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Fiber laser processing |
Development and production of prototype/Small-scale production | Grinding processing | Jig grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Arc welding High-frequency welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Mass production | Metal press | Bending Fine blanking Multi forming Shaving Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate φ0.6mm - φ9.0mm Beryllium copper precision Degreasing crimp Single press (80 - 200 t) |
Mass production | Mechanical processing | Micro-hole machining High precision |
Mass production | Sheet-metal processing | Precision sheet metal processing Angle processing Deburring process Bending process |
Mass production | Blank cutting | Laser marking Cutting process Laser and turret punch punching Laser processing (over 1.2m) Connor Shah CO2 laser processing Microfabrication (laser) Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum Precision cutting |
Mass production | Welding / welding | CO2 welding Arc welding High frequency welding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (rack) Tin (rack) Copper (rack) Acid pickling Electrocasting Chemical conversion coating Tin-zinc alloy plating (rack) Iron Copper Brass Aluminum |
Surface treatment | Polishing/Lapping | Tool polishing Blade polishing Brush polishing Buffing |
Surface treatment | Printing and others | Laser engraving |
Surface treatment | Lap polishing | Lap polishing Lap mirror polishing Single-face lapping and polishing |
Surface treatment | Heat treatment | Salt bath quenching |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Electrical part | Harness processing Cable manufacturing Cord manufacturing Coil manufacturing |
Auto parts manufacturing | Drive system part | Transmission Drive shaft |
