Machine element
MIKI PULLEY
This belt type continuously variable transmission changes the pitch diameter of the speed change belt by manually adjusting the width of the speed change pulley on the motor side, and the pitch diameter of the speed change pulley on the machine side changes accordingly. Using this principle, users can freely control the rotational speed, enabling efficient power transmission in a variety of industrial applications. Intuitive handle operation allows for tasks that require precise speed adjustment.
■ Features
Fine speed adjustments can be made by simply turning the handle.
Smooth speed changes are achieved by adjusting the pitch diameter of the speed change belt by changing the width of the speed change pulley.
The machine side variable speed pulley automatically follows the pitch diameter, ensuring efficient power transmission.
Stepless speed control enables optimal speed settings depending on the application.
■ Specifications
Composition: Motor side speed change pulley, machine side speed change pulley, speed change belt
Operation method: Adjust the width of the speed change pulley using the handle
Features: Stepless speed adjustment
This belt-type continuously variable transmission meets the needs for flexible speed control in a wide variety of industrial machinery, contributing to greater work efficiency and accuracy.
Company name | MIKI PULLEY (THAI) CO., LTD. | EMIDAS Member Number | 100370 |
Country | Kingdom of Thailand | Street address |
1 MD Tower, 20th Floor, Room No. C1, Soi.Bangna-Trad 25, Debaratna Road, Bangna-Nuea, Bangna Bangkok Kingdom of Thailand |
Telephone number | +66-2-003-5525 | Fax number | Log in to display |
Employees | 2,000,000 THB | Annual sales | |
Employees | 5 | Person in charge | Mr.Kenji Hayasaka |
