Machine element
MIKI PULLEY
An overload protection device protects the machine by instantly disconnecting the input and output in the event of an overload. Overload is reliably detected, and when the drive key is removed from the groove, the input and output are separated, and when the overload is removed, they are automatically connected again with the same torque and the same index position. The torque is set using an internally built-in torque spring, so there is no need for troublesome work such as fine adjustments. It also serves as a flexible coupling, and can be used in both two-axis butting and wrapping methods. Furthermore, since power is transmitted through a drive key, there is no problem using it in oil.
Features
- Overload Detection: Reliably detects overloads and instantly disconnects input and output.
- Automatic Reconnection: Automatically reconnects with the same torque and position once the overload is removed.
- Easy Torque Adjustment: Set using the internal torque spring with no need for fine adjustments.
- Flexible Coupling Function: Can be used for both shaft alignment and wrapping methods.
- Usable in Oil: Power transmission via drive key allows for use in oil environments.
Specifications
- Torque Setting Method: Set via torque spring
- Power Transmission Method: Drive key method
- Overload Detection: Instantly detects overload and disconnects input and output
- Reconnection Method: Automatic reconnection after overload removal
- Operating Environment: Usable in oil environments
Applications
- Industrial Machinery: Ideal for protecting machinery on production lines.
- Construction Machinery: Protects machinery in high-load working environments.
- Automation Systems: Used for overload protection in automation systems.
- Agricultural Machinery: Useful for protecting machinery under harsh conditions.
Miki Pulley's overload protection device (torque limiter) provides precise power control and machinery safety across a wide range of applications.
For more details, please download the PDF or feel free to contact us.
Company name | MIKI PULLEY (THAI) CO., LTD. | EMIDAS Member Number | 100370 |
Country | Kingdom of Thailand | Street address |
1 MD Tower, 20th Floor, Room No. C1, Soi.Bangna-Trad 25, Debaratna Road, Bangna-Nuea, Bangna Bangkok Kingdom of Thailand |
Telephone number | +66-2-003-5525 | Fax number | Log in to display |
Employees | 2,000,000 THB | Annual sales | |
Employees | 5 | Person in charge | Mr.Kenji Hayasaka |
