PR message
At MIKIPULLEY, we are dedicated to manufacturing - combining our passion for power transmission control equipment, the technology we have cultivated, and our proactive spirit to adapt to the times and conditions and deliver new value that is useful to our customers. , society, and industry. Please leave it to us regarding transmissions and reduction gears.
The Torque Tender TT01 is a high-precision overload protection mechanism designed to quickly and reliably protect equipment when an overload occurs. The input and output are instantly disconnected by the drive key disengaging from the groove, ensuring the safety of the equipment. Once the overload is removed, it automatically reconnects at the same torque and position, resuming operation. This product can be used for two-shaft coupling and also serves as a flexible coupling. It is particularly suitable for precision machinery such as semiconductor manufacturing equipment, textile machinery, and printing machines.
Features
- Automatic Reconnection Function: When the overload is eliminated, it automatically reconnects at the same torque and indexing position.
- Easy Torque Setting: The internal torque spring allows for easy torque setting without the need for fine adjustments.
- Versatile Application: It can be used for two-shaft coupling and also functions as a flexible coupling.
- High Reliability: Provides high reliability in various industrial machines, including semiconductor manufacturing equipment, textile machinery, and printing machines.
Specifications
- Supported Shaft Diameter: 8mm – 50mm
- Maximum Torque: 200Nm
- Material: High-strength aluminum alloy
- Operating Temperature Range: -25℃ – +120℃
- Torque Setting Range: 0.2Nm – 200Nm
- Dimensions: Diameter 42mm, Length 120mm
- Maximum Rotational Speed: 1800 min-1 (up to 500 min-1 for size 4X)
Applications
- Semiconductor Manufacturing Equipment: Achieves high reliability with precise overload protection.
- Textile Machinery: High-performance protection for machines requiring delicate operation.
- Printing Machines: Overload protection for machines that require continuous operation.
The Torque Tender TT01 is the optimal solution for balancing precision control and overload protection. Its function of protecting devices during overload and automatically reconnecting supports efficient operation.
The Torque Tender TT03 is a high-precision overload protection mechanism designed to quickly and reliably protect equipment when an overload occurs. When overloaded, the drive key disengages from the groove, instantly disconnecting input and output. Once the overload is removed, it automatically reconnects at the same torque and position, resuming operation. Torque setting is easily done with the internal torque spring, eliminating the need for fine adjustments. The TT03 type is used for winding, where the shaft is inserted into the hub and pulleys or gears are set in the housing to transmit power. It can be used in a wide range of applications, including semiconductor manufacturing equipment, textile machinery, and printing machines.
Features
- Versatile Application: Used for winding, with the shaft inserted into the hub and pulleys or gears set in the housing.
Specifications
- Supported Shaft Diameter: 8mm – 45mm
- Moment of Inertia: 0.09 × 10⁻³ kg·m² (TT-1X-03), 0.31 × 10⁻³ kg·m² (TT-2-03), 0.66 × 10⁻³ kg·m² (TT-2X-03), 1.59 × 10⁻³ kg·m² (TT-3-03), 2.43 × 10⁻³ kg·m² (TT-3X-03), 15.8 × 10⁻³ kg·m² (TT-4X-03)
Applications
The Torque Tender TT03 is the optimal solution for balancing precision control and overload protection. Its function of protecting devices during overload and automatically reconnecting supports efficient operation.
The rotation indicator with SDH handle is a high-precision device designed to simplify the confirmation and management of rotations. By equipping the standalone models SD-53 and SD-75 with a handle, ease of use and functionality have been improved. Handle diameters range from φ66mm to φ250mm, and the indexing performance is excellent, just like the standalone models. This allows for the selection of rotation ratios to meet various applications and requirements.
Features
- User-Friendly Handle Design: Handle diameters ranging from φ66mm to φ250mm are available, providing the optimal size for various applications.
- High-Precision Indexing Function: Equipped with the same high-precision indexing function as the standalone models SD-53/75.
- Wide Range of Rotation Ratios: Options include 1/4, 1/5, 1/6, 1/9, 1/12, 1/16, 1/25, 1/36, 1/40, 1/49, and 1/64.
- Excellent Visibility: The smoothly moving needle and easy-to-read scale allow for quick confirmation of rotation numbers at a glance.
- Robust Design: Durable aluminum handle and highly reliable structure.
Specifications
- Models: SD-53, SD-75
- Handle Diameters:
SD-53: 66mm, 80mm, 140mm
SD-75: 125mm, 160mm, 180mm, 250mm
- Rotation Ratios: 1/4, 1/5, 1/6, 1/9, 1/12, 1/16, 1/25, 1/36, 1/40, 1/49, 1/64
- Weight:
SD-53: 0.075kg
SD-75: 0.135kg
- Operating Temperature Range: -20℃ to 60℃
- Material: Aluminum (handle part)
- Direction: Clockwise, Counterclockwise (scale direction selectable)
Applications
- Industrial Machinery: Ideal for use in industrial machinery that requires precise rotation management.
- Production Lines: Easily manage rotations in various manufacturing processes.
- Research and Development: Precise rotation measurement in experimental and development processes.
The rotation indicator with SDH handle is the ideal solution for achieving ease of use and high-precision rotation management. With various rotation ratios and handle diameter options, it supports a wide range of applications.
The rotation indicator SDS (differential type) is a high-precision device where the dial rotates in the same direction as the rotation axis. This product allows you to choose between scales that increase in the clockwise or counterclockwise direction, and a scale-less type that lets users write their own scales. As a differential type, it is not limited by mounting direction like the weighted type, allowing installation in any orientation. This flexibility makes it adaptable to a wide range of applications and installation environments.
Features
- Customizable Scale Settings: Options for scales that increase in the clockwise or counterclockwise direction, as well as a scale-less type for user-defined scales.
- Flexible Mounting Directions: Unlike the weighted type, it has no restrictions on mounting direction and can be installed in any orientation.
- High-Precision Differential Mechanism: The dial rotates in the same direction as the rotation axis, providing accurate rotation indication.
- Versatile Applications: Designed to adapt to various installation environments and uses.
Specifications
- Models: SD-50, SD-100
- Scale Increase Direction: Clockwise (R), Counterclockwise (L), Scale-less (N)
- Rotation Ratios:
SD-50: 1/20
SD-100: 1/25, 1/50
- Weight:
SD-50: 0.06kg
SD-100: 0.27kg
- Material: High-durability aluminum
- Dimensions:
SD-50: Diameter 50mm, Height 23mm
SD-100: Diameter 100mm, Height 32mm
Applications
- Production Lines: Achieves accurate rotation measurement in various manufacturing processes.
- Research and Development: Provides precise rotation management and measurement in experimental and development processes.
The rotation indicator SDS (differential type) is a high-precision solution that offers flexible mounting and customizable scale settings. It adapts to various installation environments and ensures precise rotation management across a wide range of applications.
The rotation indicator SD (standalone) is designed to measure the rotation speed of the rotation axis with high precision. This model is categorized by outer diameter sizes into 28, 38, 53, and 75. Sizes 28 and 38 are integrated handle models, which are directly attached to the rotation axis. In contrast, sizes 53 and 75 allow for customizable handle designs or can be selected with handle set models. All types offer the choice of one or two pointers and a variety of rotation ratios, allowing customers to select the type that best suits their needs.
Features
- Various Size Options: Available in sizes 28, 38, 53, and 75, providing the optimal size for different applications.
- Integrated and Customizable Handle Designs: Sizes 28 and 38 are integrated handle models, while sizes 53 and 75 allow for customizable handle designs.
- Pointer Options: Choice of one or two pointers.
- High Reliability: Durable aluminum handle and robust structure ensure long lifespan.
Specifications
Models: SD-28, SD-38, SD-53, SD-75
Rotation Ratios:
SD-28: 1/4
SD-38: 1/4, 1/9
SD-53: 1/4, 1/5, 1/6, 1/9, 1/12, 1/16, 1/25
SD-75: 1/4, 1/5, 1/6, 1/9, 1/12, 1/16, 1/25, 1/36, 1/40, 1/49, 1/64
Number of Pointers: One or two
Weight:
SD-28: 0.06kg
SD-38: 0.10kg
SD-53: 0.075kg
SD-75: 0.135kg
Outer Diameter Sizes:
Applications
The rotation indicator SD (standalone) is a highly reliable measurement device that enables precise rotation management. It supports a variety of applications and offers a wide range of options.
Miki Pulley's electric linear actuator provides a simple yet high-performance drive system. The linear shaft drive detects positions using the magnetic flux built into the shaft, allowing operation without external position sensors. This simplifies the system and reduces costs. Additionally, the driver has a built-in positioning function, making complex positioning operations easy to execute.
Features
- No Need for External Position Sensors: Position detection using the magnetic flux from the shaft eliminates the need for external position or origin sensors.
- Built-In Positioning Function: The driver has a built-in positioning function, allowing positioning operations without an external controller.
- Versatile Applications: Suitable for a wide range of fields, including optical equipment, semiconductor manufacturing devices, food machinery, and inspection equipment.
- Easy System Construction: Simple structure and high performance enable efficient system construction.
- Environmental Resistance: Complies with JIS Protection Rating IP65, providing dust and water resistance for use in various environments.
Specifications
Motor Shaft Diameter: φ16mm, φ25mm
Rated Thrust:
φ16mm: 11N, 16N, 25N
φ25mm: 28N, 59N, 90N, 118N
Maximum Speed:
φ16mm: 4000mm/s
φ25mm: 2600mm/s to 4000mm/s
Effective Stroke Length:
φ16mm: 199mm to 1045mm
φ25mm: 117mm to 1041mm
Structure: Fully enclosed, self-cooling
Material:
Shaft: SUS304
Movable Part: A6063S
Operating Temperature Range: 0℃ to 40℃
Environmental Conditions: Relative humidity below 80% (non-condensing)
Applications
- Optical Equipment: Ideal for driving optical equipment that requires high-precision positioning and smooth operation.
- Semiconductor Manufacturing Devices: Perfect for use in semiconductor manufacturing devices that require delicate operations.
- Food Machinery: With dust and water resistance, it can be used safely in food processing and manufacturing environments.
- Inspection Equipment: Ideal for use in inspection equipment that requires high-precision positioning.
Miki Pulley's linear shaft drive is the ideal solution for achieving simple system construction and high-performance driving. It supports a wide range of applications and enables efficient operations.
The OPC-1703 is a control panel designed to achieve synchronous operation of multiple drive systems without mechanical coupling, using variable speed motors (such as the inverter V7 series and DC motors SC and SY series). Traditional proportional operation systems tend to accumulate errors regardless of precision improvements, but the OPC-1703 employs position control using synchro motors (86G-L, 86CT-L) to ensure complete synchronous operation. Additionally, it has enhanced functionality over the previous OPC-1701 model by adding synchronous signal output (start point) and step-out signal output features for more comprehensive synchronous control.
Features
- High-Precision Synchronous Operation: Utilizes position control with synchro motors (86G-L, 86CT-L) to achieve complete synchronous operation without error accumulation.
- Additional Features: Adds synchronous signal output (start point) and step-out signal output to the existing OPC-1701 features.
- Simple Adjustments: Basic adjustments are limited to proportional signal adjustment and correction GAIN adjustment, making it easy to configure.
- No Need for External Sensors: Position determination by synchro motors eliminates the need for other sensors or homing operations.
- Monitoring Operation Status: Synchronization status can be checked via meters on the control panel.
Specifications
Power Supply: AC 200/220V single-phase
Phase Difference Input/Output: AC 52V
Tachogenerator Input: AC, DC 100V max.
Output 1 (OUT): DC 0–10V
Output 2 (REF OUT): DC 0–10V
Output Contact Capacity: AC 250V, DC 30V, 0.5A
Accuracy: ±0.5°
Rotation Speed of Synchro Transmitter (86G-L) and Control Transformer (86CT-L): ≤200 min⁻¹
Maximum Number of Synchro Receiver Connections: 18 units
Synchronous Signal Detection Range: 0° to -45°
Step-Out Detection Range: Within ±30°
External Proportional Input: DC 0–10V
Soft Start/Stop: 0.4–40s each
Applications
- Food Machinery: Ideal for synchronous operation aligning feeders and conveyors.
- Printing Machines: Synchronous operation for continuously running rollers.
- Textile Machinery: Suitable for applications requiring high-precision synchronous operation.
- Paper Machinery: Synchronous control of various drive systems.
- Bookbinding Machines: Synchronous operation of collators and binders.
- Packaging Machines: Synchronous operation of rotary cutters and films.
- Others: Electrical synchronous operation of drive systems that cannot be mechanically coupled, such as chains and line shafts.
The OPC-1703 is the ideal solution for achieving high-precision synchronous operation of multiple drive systems. Its position control without the need for external sensors and simple adjustments support efficient operation.
Miki Pulley's V7 inverter is a high-performance inverter with double the processing power of the previous V6 model. Featuring the fastest level CPU and proprietary dynamic torque vector control, it ensures stable operation even at low speeds. It retains the user-friendly series design, with complete compatibility in dimensions, installation dimensions, number and position of terminals. Additionally, it comes standard with the highly requested RS-485 communication port, making it a compact and high-performance inverter suitable for a wide range of applications.
Features
- High-Performance CPU: Equipped with a high-performance CPU that delivers double the processing power compared to the previous V6 model, achieving more advanced control.
- Dynamic Torque Vector Control: Proprietary control method ensures stable operation even at low speeds.
- Fully Compatible Design: Dimensions, installation dimensions, number and position of terminals are compatible with previous models, making it easy to integrate into existing systems.
- Standard RS-485 Communication Port: Enhanced communication functions allow for remote operation and monitoring.
- Versatile Applications: Stable torque at low speeds makes it suitable for a wide range of applications, including high-inertia loads and transport machinery that require high starting torque.
Specifications
Control Method: Dynamic torque vector control
Motor Output:
Supports 0.1kW to 3.7kW
Low-Frequency Characteristics: 3Hz
Communication: Standard RS-485 communication port
Cooling Method: Self-cooling or fan-cooled
Operating Temperature Range: -10℃ to 50℃
Dimensions:
0.1kW model: 80mm x 120mm
0.2kW model: 80mm x 120mm
0.4kW model: 95mm x 120mm
0.75kW model: 120mm x 120mm
1.5kW model: 130mm x 118mm
2.2kW model: 130mm x 118mm
3.7kW model: 140mm x 168mm
Weight: 0.6kg to 2.5kg (varies by model)
Protection Structure: IP20
Certifications: UL508C, IEC 61800-5-1:2007
Applications
- Food Machinery: Achieves precise transport due to stable torque at low speeds.
- Printing Machines: Improves print quality with high-precision speed control.
- Textile Machinery: Suitable for delicate operations required in textile processing.
- Paper Machinery: Ideal for synchronous control of various drive systems.
- Bookbinding Machines: Supports synchronous operation of collators and binders.
- Packaging Machines: Enables synchronous operation of rotary cutters and films.
- Others: Applicable to high-inertia loads and transport machinery requiring high starting torque.
The V7 inverter is the ideal solution for achieving high-performance control and easy operation. It supports a wide range of applications and ensures efficient operation.
Company name | MIKI PULLEY (THAI) CO., LTD. | Website URL | |
Street address |
1 MD Tower, 20th Floor, Room No. C1, Soi.Bangna-Trad 25, Debaratna Road, Bangna-Nuea, Bangna Bangkok Kingdom of Thailand
[See map] |
Person in charge | Mr.Kenji Hayasaka |
Telephone number | +66-2-003-5525 | Fax number | Log in to display |
Capital | 2,000,000 THB | Employees | 5 |
Annual sales | Unregister | EMIDAS Member Number | 100370 |
Main 3 products |
