PR message
Global Group was formed by a group of professional engineers with more than 20 years of experience in designing, researching, and develop quality construction products and services that exceed expectations By focusing on meeting the needs of industrial customers, factories, warehouses, warehouses and housing.
Installation service for aluminum composite panels of all models and brands, all over the country.
Nowadays, we often see new innovations in construction that happen all the time. One of them is a material that is beautiful, unusual, and has great properties like aluminum composite, which is popularly used for building wall decoration. Whether it is a factory building, warehouse, warehouse, or various office buildings, both external and internal walls are necessary.
Aluminum composite is a material that can be modified and designed into a variety of shapes. It is a modern building decoration innovation that meets the needs of various projects. At present, aluminum composite material has become the most popular interior and exterior decoration material.
Advantages of aluminum composite for building decoration
1. Lightweight, weighing only 3.5 to 5 kg per square meter
Due to the fact that aluminum composite is a lightweight and highly flexible material, making it convenient to install Quick to install and safe to use It also helps to reduce the load on the structure that must support the weight of the building walls. making it an ideal material for building buildings in premium-grade real estate, such as factories for rent, warehouses for rent, office buildings, etc.
2. Aluminum composite materials and coatings are durable. Strong, lasting for ten years
Aluminum composite does not retain moisture, does not rust, and does not scratch. no fungus It is durable and has durability properties. Making it last for more than 10 years is also considered good for the health of people living in the building. and can also maintain It is easy to clean and reduces maintenance costs as well.
3. Aluminum composite panels come in a variety of shades. Support for all styles of design
Aluminum composite panels are available in both normal color tones and natural material colors with smooth, beautiful surfaces. There are 36 standard colors to choose from. and can also be colored as needed, thus helping meet the needs of those who want to be unique. It also makes factory buildings, warehouses, and offices unique, beautiful, modern, and luxurious. It is well remembered by people.
4. Aluminum composite paneling is easy to assemble and install. Saves both money and time.
It is lightweight and designed to be installed quickly and easily, and it can also be cut with tools or equipment for wood or aluminum. It is also lightweight. Capable of freely planning usage, splitting, folding sheets, or bent cutting.As a result, it saves work time. make installation fast, and it also saves installation costs as well.
5. Aluminum composite panels can be easily bent and formed.
With the unique properties of aluminum composite, it can be processed into a variety of different shapes. Therefore, it is a suitable material for architectural works and constructions that require a unique identity. Making the building unique, luxurious, and modern
6. Help reduce heat levels and soundproofing inside the building.
The aluminum composite panel provides excellent heat dissipation and also helps to insulate the interior from sound. It is also weather- and UV resistant, enabling it to maintain its color and gloss for long periods of time in any environment. It is also used as an insulator to prevent heat radiation from entering the building.
7. There are many forms of use.
We can use aluminum composite panels for a variety of applications, such as covering the entire surface of high-rise buildings. which can be attached interchangeably with glass as well, making a scene, a wall, both exterior and interior, or can be covered with round columns and square columns. In addition to being used to cover the surfaces of the ceiling and facade of the building, it can also be used in advertisements and various product shows.
Roof sheet installation service
- Metal Sheet Roofing
- Ceiling metal sheet (spangle metal sheet)
- Metal sheet panels and wall cladding
- Metal sheet roof covering joint cover plate flashing
- Aluminum Sheet Roofing
- Aluminum sheet ceiling (spandrel aluminum sheet)
- Aluminum Sheet Panel and Wall Cladding
- Aluminum sheet roof cover joint cover plate flashing
- Translucent roof sheet Transparent tiles (fiberglass), skylight sheets (Skylite), Delight (D-Lite)—double corrugated sheets, single corrugated sheets, and aluminum sheets
- Metal sheet louvers made from sheet metal
- Aluminum sheet louvers made from aluminum sheet
- Louver made of translucent or clear fiberglass sheet (Fiberglass Louver)
- Galvanized battens and purlins for use with tiles; - CPAC monitor
- Steel batten screws and self-drilling screws for aluminum sheet
- PE insulation, PE foam, and PE (Polyethylene Polyethylene: PE) for attaching under the aluminum sheet
- PU insulation, PU foam, and PU (Polyurethane) for injection under the aluminum sheet
- Aluminum Sheet Fencing
roof installation service
Friendly service
- Retail-wholesale metal sheet roof Aluminum sheet and equipment, or other roof materials
- Consulting work, construction contractor, office building, metal sheet roofing factory Aluminum sheet
- consultation for metal sheet roof work on an aluminum sheet roof is free!
- Request a quote for metal sheet roof structures.
- Installation of a metal sheet roof Aluminum sheet and aluminum sheet awning
- Take off the metal sheet roof structure. Aluminum sheet Please send a drawing or size drawing to sale.globalgroup@gmail.com. Or come to the office or factory to speak with someone in person.
Pick-up and delivery Aluminum sheet roof
Convenient pick-up and delivery The factory is near the expressway.
- Please see the route map to our factory.
- If you pick up the product yourself at the factory Be sure to inspect all products completely before moving the car out of the factory. If there is damage during transportation, we will not be responsible for any product.
- the price we offer Shipping costs are not included (items are sold separately).
- If the customer does not have a car to pick up the product by himself, we are happy to provide a transportation vehicle at an affordable price.
- If the customer wants a car with product damage insurance, please notify the team.
- Transportation that we provide He is well versed in the transportation of steel. to prevent damage and delays that will happen
- Delivery of roofing materials both in Bangkok and other provinces throughout Thailand at an affordable price
Roof removal
Help find the amount of work and the amount of material used.
- Please send the form to sale.globalgroup@gmail.com.
- The model sent may be a hand-written-size picture or a blueprint drawing, or a PDF, AUTOCAD, Word document, or Jpeg or GIF image file.
- To ensure that the work is not delayed, please specify the necessary details completely and clearly: name, phone number, fax number, size, measurement unit.
- If it is convenient for the customer to come and meet with the team, To come and contact us by yourself at our office or factory at any time on the opening day and time.
Purlin roof purlins, ready-made roof purlins, and roof purlins for the installation of corrugated tiles G330 metal sheet roof purlin with galvanized coating (200 grams per square meter)
details
Profast purlin, with a thickness of 1 millimeter, is made from high-tensile steel (High Tensile Steel G330) coated with galvanized rust. modern machinery According to the engineered profile, it is strong while being lightweight, combined with high tensile properties, allowing technicians and users to successfully step on the purlin without bending when installed. until deformed, like the use of sectional steel
Product specification
Size: spine 20 mm., height 27 mm., and base 61 mm.
Thickness: 1 mm.
Type of steel: G330
Tensile strength: 3300 kg/cm2.
Coating: galvanized
Length: 6 m.
Storage: Store in the shade, not exposed to the sun or rain, at a temperature of 15 to 40 degrees.
Weight: 4.6 kg.
installation
Rafter distance: maximum 1.5 m.
Batten distance: maximum 1 m.
Spacing per rafter batten: at least 5 cm.
Spacing between purlins without supporting rafters: at least 20 cm.
Z-purlin steel
Z purlin for general structural work Making roof structures Various purlins are purlins that have one wing slightly wider than the other. so that it can be turned over and stacked together completely when wanting to connect the purlins. Can be used for both single laying and continuous spanning without overlap. Including continuous crossing with overlapping of Z purlins.
which is a Z pillar that is connected by overlapping The Z-shaped wingtips are available in two types: 90-degree wingtips and 45-degree angled wingtips.
It is able to bear strength up to two times better because it is a steel plate that is stronger than general steel. by design efficiently This enables the structure to be laid out up to 18 meters long. It can be laid on the batten in both single and continuous spans.
Z-shaped high-strength steel purlins are a new innovation that can meet high-precision steel frame or roof purlin work. Lightweight but of high strength, it can be installed conveniently and quickly, saving time and money, and can reduce a lot of costs when compared to conventional work in the market with these outstanding characteristics:
1. Manufactured from high-strength steel with a minimum yield strength of 450 MPa.
2. Can be produced according to the required length.
3. They can be used for both welding and fastening systems.
4. Available in both anti-rust zinc coating (galvanized Z-275) and non-coated anti-rust (cold rolled).
Square steel pipe / square pipe / galvanized square tube (Galvanized Square Tube)
Square steel pipe / square pipe / square box, galvanized, looks like a square cross-section steel pipe. Manufactured from GI coil steel, cut into sheets (slits) and then rolled up to the desired size. can last longer than non-galvanized steel It is often used in rust proof structures. to encounter humidity Can be used outside because it is reasonably rust resistant, such as roof structures, street lamp posts, wall frames, rain gutters, etc.
Square Tube
Square steel pipe / square pipe (For various structures such as columns, beams, scaffolding and roof structures) is a square section steel pipe. can be applied in general work substitute for wood Concrete and other types of steel due to its strength, durability, light weight.
A steel structure is a metal structure made of structural steel. The components are connected to each other for load-bearing and full strength.
due to high-strength steel This structure is reliable and requires fewer raw materials than other structures, such as concrete and wooden ones.
In modern construction,steel structures are used for almost all types of structures. Including heavy industrial buildings, high-rise buildings, equipment support systems, infrastructure, bridges, towers, airport terminals, pipe racks, etc.
Steel structures, including substructures or parts of buildings, are made of steel. Structural steel is a building material made of steel. which are made to a specific shape and chemical composition to suit the use of each project
The main ingredients of structural steel are iron and carbon, manganese, alloys, and some chemicals. Added to steel and carbon to increase strength and durability.
Depending on the requirements of each steel structure construction project It is formed by hot or cold rolling. or made by welding flat sheets or bent them together
Steel structures come in many shapes, sizes, and specifications. The most common shapes are I-beams, rails, and angles.
- I-Beam: I-shaped cross-sectional shape
- Z-Shape: looks like a Z, with only half of the wings protruding in opposite directions.
- HSS-Shape: Hollow-section structure including rectangular, circular (tube), and oval cross-sections.
- Angle: steel with an L-shaped cross-section
- Gutter structure, channel: C-shaped beam or C-shaped cross-sectional steel
- Tee: T-shaped section steel
- Railway System: Steel parts are used to assemble all railway tracks.
- Bar: A piece of metal, a rectangular section of steel that is long but not wide, is called a plate.
- Rod: A piece of metal in the shape of a circle or square, of any length; construction rebar; dowel.
- Plate: metal plate thicker than 4 mm.
type of main structure
- truss structure: bar or truss parts
- Building frame structure: beams and columns
- grid structure: slat or dome structure
- curved structure
- Prestressed concrete structure
- girder bridge
- truss bridge : a piece of truss
- arch bridge
- Cable-stayed bridge
- suspension bridge
A rolling door is one of the unique door styles for opening and closing applications. with a unique identity It is a component of buildings, houses, factories, and warehouses, which are constantly being developed. The pattern of the door to open and close by pushing up and pulling down. There is a pulley inside that acts as a roller to allow the door to be folded. or can be pulled out as a sheet that is comfortable to use. It helps completely close the entrance and exit, and when you activate As for the door, it will be kept in an orderly manner, looking comfortable.
rolling shutter door system
Available for installation of rolling steel doors, hand pull systems are strong, durable, and can be used for a long time. Suitable for warehouses, factories, commercial buildings, and residences The hand-pull system relies on the function of the spring to open and close the door, which is controlled by manpower. with springs to help relieve stress, or if the door has a relatively large height, you may use accessories like a hook for a rolling shutter. Helps to pull it on and off. will make it more convenient for users.
For rolling shutters, hand-pull systems Suitable for doors with a width of not more than 4.00 meters and a height of not more than 3.50 meters. The average weight of the door leaf is not more than 100 kilograms. may be used as a chain hoist system or motor system, or divide the door by adding a central pillar, depending on demand and the suitability of the user.
Metal sheet
metal sheet roof
Metal sheet roof (metal sheet) or steel roof It is a roofing sheet made of steel coated with aluminum alloy (aluminum) and zinc (zinc). The production will be formed from smooth steel sheet into a variety of corrugations according to the needs and suitability of each site.
Metal sheet has outstanding features in terms of weather resistance, strength, light weight, and ease of workability. fast installation save structure cost There are many styles, many colors, and a long service life.
Global Roof Co., Ltd. distributes metal sheet roofing in various forms and thicknesses ranging from 0.20-0.50 mm for suitability in various forms.
metal roof sheet color
Metal roofing sheets come in many colors and shades from different steel manufacturers. The company is a large corrugated steel roofing sheet rolling mill that has brought steel or coil balls from leading steel sheet manufacturers both inside and outside the country to distribute and produce corrugated steel sheets. It's a sheet metal roof.
Color Metal Sheet
Castle Red Castle Red Color Brick Red Castle
Tiger Red Tiger Red Bright red
Shogun Orange Shogun Orange Color: Fresh orange
Natural Brown Color Natural Brown Color Dark Brown
Forest Green Color Forest Green Color Dark Green Forest Green Trees
Green Bright Green Bright Green Color Bright green
Bangchak Green Bangchak Green: similar to Bangchak Pump Color
Green banana leaf Banana Leaf Color: light green
Jade Green Jade Green Jade Green
Peanut Butter Cream Color Peanut Butter Cream Color
Yellow Mango Yellow Mango
Novo Blue Novo Blue Color: dark blue
Ocean Blue Color Ocean Blue Color Sea Blue
Sky tone blue Skytone Blue Sky blue
Alloy gray Asian white color Alloy gray Alloy metal color
White Asian White Asian Color White
Aluzinc Color Colorless or Zinc Color
Benefits of metal roofing
1. Good heat dissipation The roof of the house is another important material that will help keep our homes cooler. Metal sheet roofs can dissipate heat better than tiled roofs during the night, when the roof of the house will release heat from absorbing heat during the day. Makes the house that is attached to the metal sheet roof feel cooler faster.
2. Can be used in a variety of applications with strength Aside from being a roofing material, the beauty looks good, modern, metal sheet.Can also be used as ceilings, wall panels, and ventilation louvers.
3. There is a continuous length to the sheet. Metal sheet is made by rolling steel into long curls. making it look like it stretches into the same sheet Thus helping to completely eliminate the fussy problem that homeowners do not want to encounter, such as roof leakage.
4. Metal sheets can prevent heat. Metal sheeting itself can add heat protection properties by attaching PE/PE insulation or spraying PU foam covered with aluminum foil. Therefore preventing heat and UV radiation. In addition, PE or PU foam insulation also helps reduce sound caused by objects hitting the roof.
5. It doesn't take long to install. The metal sheet roof has the same wavy shape along its entire length, allowing for quick installation. Different from small tiles that have to be placed one by one.
6. Can support low degrees Metal sheet roofs can only support a slope of 4-5 degrees and, in some cases, can accept as much as 2 degrees because they look like the same sheet. while tiled roofs cannot
7. Light weight: Due to the light weight of the metal sheet, it can help save on the roof structure. And most importantly, the metal sheet can be bent to match the look of the roof, such as a gable roof or hip roof that has a sloping pattern that flows down to the wall. Therefore, there is an uneven slope, so the metal sheet is a great answer.
Company name | GLOBAL GROUP CO.,LTD | Website URL | https://www.globalgroupthailand.com/ |
Street address |
Don Hua Lo Subdistrict Mueang Chonburi District Chonburi Kingdom of Thailand
[See map] |
Person in charge | Nan |
Telephone number | +66-89-685-0808 | Fax number | +66-- |
Capital | 60,000,000 THB | Employees | Unregister |
Annual sales | Unregister | EMIDAS Member Number | 100281 |
Main 3 products |
