PR message
Motoyuki Co., Ltd. has been manufacturing 'Global Saw T.C.T' brand tipped saws for over 34 years.We have acquired ISO 9001 and 2000 certification with our advanced manufacturing technology, selecting materials, and using our technologically developed production process.In addition, we won the Good Design Award, which is considered to be the highest award in the Japanese industrial world, for our diamond-tipped saw.
using foe welding bead removal, Rust removal, Deburring, Chamfering and surface grinding 10 grades of grinding disc.
use for multi material cutting, steel, stainless, non-ferrous cutting resin, steel sheet and
cast iron
Feature : Formulating strongest balance between polycrystalline alumina abrasive grains and super-hard bond to achieve powerful grinding
usage : steel
SC-I,SC-II : for low carbon, mild and alloy steel
STC : for bearing and carbon steel
STS : for stainless steel
Feature : it can cut various cutting materials, it is convenient for tear down and reform
low noise, fluorine coating
usage : wood construction materials,plastic resin system,aluminium (non-ferrous metal cutting) can't cut thick steel materials (more than 3 mm)
Good cost performance
feature : standard type for steel cutting
suitable for relative thin cutting materials
usage : angle steel,sheet steel,channel steel,steel pipe,deck gas pipe,hanger rail
Feature : multi use, it is good for cutting acrylic and sheet metal
Usage : PVC,plastic,metal siding,color galvanized sheet iron and thin steel less than 1.0mm. but can't cut grass fiber which includes resin
Company name | MOTOYUKI (THAILAND) CO., LTD. | Website URL | http://www.motoyuki.co.th/about.html#about_ |
Street address |
Bang Krasor Subdistrict Mueang District Nonthaburi Kingdom of Thailand
[See map] |
Person in charge | Rungsee |
Telephone number | +66-2-192-6885 | Fax number | +66-2-192-6886 |
Capital | 1,000,000 THB | Employees | Unregister |
Annual sales | Unregister | EMIDAS Member Number | 100118 |
Type of manufacturing | Industrial machinery | ||
Main 3 products |
Large | Medium | Small |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
