Machine tools
Robot
Manufacturing facilities
This product can be used as a workpiece conveyor, etc.
Filtration accuracy
20mm 90% or more
Flow rate(L/min)
150
Screw type conveyor using magnet.
The rotating part is not exposed, so this can be used safely and se curely.
Optimum for cutting chip processing of gear cut ting machines, broach machines, etc.
Features
・The rotation axis of the magnet is inside the fixed pipe, so there are only a few problems such as chip biting, which enables you to use this product safely.
・Also suitable for dry processing based on the heat resistant specifications.
・This product does not use any consumables such as cartridges or paper filters, so no industrial waste is generated.
Coolant
Water soluble / Oil-based
Category
Magnetic material
Processing details
Cutting
Work material
FC/FCD Steel
Chip shape
Granular / Small curl-shaped (50 mm or less)
Grinding chip size
Machine tool
Machining center / Broaching machine / Gear cutting machine
* The filtration accuracy is based on the results of our experiments, and does not imply that this level of accuracy is guaranteed.
You can download a comprehensive catalog that covers Bunri’s products.
https://www.bunri.com/en/download/
Company name | BUNRI Inc. | EMIDAS Member Number | 100081 |
Shinagawa-ku Tokyo Japan |
Telephone number | +81-3-3778-2061 | Fax number | +81-3-3778-2063 |
Employees | 60,000,000 JPY | Annual sales | |
Employees | 160 | Person in charge | Kouhara |
Type of manufacturing | Machine tools / Industrial machinery |
