Machine tools
Robot
Manufacturing facilities
Ultra-precision filtration system that uses steel balls as the filter medium.
The filter media is automatically cleaned by performing operations on the touch panel.
Optimum for grinding sludge processing on honing machines and super-finishing machines.
Features
・The filtration and cleaning cycle is controlled by the timer.
・The operation can be performed on the touch panel.
・The operation mode can be switched between automatic and manual modes.Even if an abnormality occurs, it is displayed on the touch panel screen.
・The filter medium (steel ball) can be removed from the main body for cleaning and maintenance.
・A vortex is generated in the primary tank using the inflow of the primarily filtered clean liquid and the overflow of the secondary tank.With its centripetal force*, sludge and abrasive grains are collected in the center of the tank.
・By improving the primary tank structure, the rotating velocity of the vortex flow has tripled compared to before the improvement.Improved centripetal force reduces sludge and abrasive deposits in the tank.
・This product is not a bag type or cartridge type, so there is no need to replace the element.
・This product does not use any consumables such as cartridge filters or paper filters, so no industrial waste is generated.* Refers to the force that acts toward the center of the circle.Vortex.
Coolant
Water soluble / Oil-based
Category
Magnetic material
Processing details
Grinding
Work material
FC/FCD Steel
Chip shape
Grinding chip size
Ultrafine particles (5 μm to 10 μm) / Fine particles (10 μm to 100 μm)
Machine tool
Honing machine / Super finishing machine (Super finisher)
You can download a comprehensive catalog that covers Bunri’s products.
https://www.bunri.com/en/download/
Company name | BUNRI Inc. | EMIDAS Member Number | 100081 |
Shinagawa-ku Tokyo Japan |
Telephone number | +81-3-3778-2061 | Fax number | +81-3-3778-2063 |
Employees | 60,000,000 JPY | Annual sales | |
Employees | 160 | Person in charge | Kouhara |
Type of manufacturing | Machine tools / Industrial machinery |
