Machine tools
Robot
Manufacturing facilities
Optimum for castings that generate fine chips because the magnetic force of the magnetic drum is higher than that of MMS.
This product does not require any secondary processing, and supports high-pressure pumps of up to 3 MPa.
Microfiltration conveyor equipped with powerful magnetic drum.
Optimum for cutting chip processing of castings and iron.
Filtration accuracy
10μm 90% or more
Flow rate(L/min)
150 to 300
Features
・No mist is generated by the in-liquid filtration, which helps improve the environment in the factory.
80 to 90% of chips settle near the dirty fluid inlet, so the magnetic drum provides efficient filtration.
・Since the power source is the geared motor of the conveyor, it helps reduce power consumption.The chain scraper and magnetic drum are driven by the same geared motor.
・The chip discharge port of the conveyor has a structure that drains liquid, which ensures that chips are drained before being discharged.This processing reduces the load to carry out coolant (means that coolant is discharged together with chips).
・Optimal design with consideration for maintenance.
・This product does not use any consumables such as cartridge filters or paper filters, so no industrial waste is generated.
Coolant
Water soluble / Oil-based
Category
Magnetic material
Processing details
Cutting
Work material
FC/FCD Steel
Chip shape
Sandy Cottony / Granular / Needle-shaped / Small curl-shaped (50 mm or less)
Grinding chip size
Machine tool
Machining center / #30 Machining center / Broaching machine / Gear cutting machine / Gun drill machine / Cutting specialized machine / Washing machine
* The filtration accuracy is based on the results of our experiments, and does not imply that this level of accuracy is guaranteed.
You can download a comprehensive catalog that covers Bunri’s products.
https://www.bunri.com/en/download/
Company name | BUNRI Inc. | EMIDAS Member Number | 100081 |
Shinagawa-ku Tokyo Japan |
Telephone number | +81-3-3778-2061 | Fax number | +81-3-3778-2063 |
Employees | 60,000,000 JPY | Annual sales | |
Employees | 160 | Person in charge | Kouhara |
Type of manufacturing | Machine tools / Industrial machinery |
