Machine tools
Robot
Manufacturing facilities
Non-magnetic material
Filtration accuracy
20μm 90% or more
Precision drum filter conveyor with high-rigidity sintered material filter.
Optimum for cutting chip processing of non-magnetic materials.
Features
・The filtration accuracy is as high as 20 μm 90% or more, so secondary processing is not required.
・This product does not require any secondary processing, and supports high-pressure pumps of up to 3 MPa.
・The filter uses a high-rigidity sintered material filter that is difficult to tear.
It is automatically cleaned by shower cleaning to prevent clogging.
・The chip discharge port of the conveyor has a structure that drains liquid, which ensures that chips are drained before being discharged.
・This processing reduces the load to carry out coolant (means that coolant is discharged together with chips).
・This product does not use any consumables such as cartridge filters or paper filters, so no industrial waste is generated.
Coolant
Water soluble
Category
Processing details
Cutting
Work material
Aluminum / Stainless / Copper / Titanium / Magnesium
Chip shape
Sandy/ Cottony / Granular / Needle-shaped / Small curl-shaped (50 mm or less) / Small curl-shaped (51 mm to 100 mm)
Grinding chip size
Machine tool
Machining center / Cutting specialized machine
* The filtration accuracy is based on the results of our experiments, and does not imply that this level of accuracy is guaranteed.
You can download a comprehensive catalog that covers Bunri’s products.
https://www.bunri.com/en/download/
Company name | BUNRI Inc. | EMIDAS Member Number | 100081 |
Shinagawa-ku Tokyo Japan |
Telephone number | +81-3-3778-2061 | Fax number | +81-3-3778-2063 |
Employees | 60,000,000 JPY | Annual sales | |
Employees | 160 | Person in charge | Kouhara |
Type of manufacturing | Machine tools / Industrial machinery |
