Machine tools
Robot
Manufacturing facilities
Cyclone-type secondary processing unit that you can use extensively regardless of magnetic or non-magnetic materials.
Compatible with fine cutting chips and grinding sludge.
The defoaming mechanism supplies the non-foaming clean liquid.
The main body has been downsized while maintaining the filtration accuracy and defoaming mechanism of the old type.
Features
・Cyclone-type secondary filtration equipment that deals with coolant containing fine chips and sludge.
It has a built-in defoaming mechanism that suppresses the foaming of clean liquid.
・By combining this equipment with the settlement tank or the settlement tank for conveyor type, drained chips and sludge can be discharged.
・By standardizing the “drain part exchange type” for wear countermeasures, even if the drain discharge part wears over time due to sludge of hard materials, you can use it for a long time by replacing parts.
・The main unit has been made approximately 40% smaller while maintaining the filtration accuracy and defoaming mechanism of the old type. As a result, the motor capacity of the supply pump can be reduced by 40-50%.
・This product does not use any consumables such as cartridge filters or paper filters, so no industrial waste is generated.
Coolant
Water soluble / Oil-based
Category
Magnetic material / Non-magnetic material
Processing details
Grinding / Cutting
Work material
FC/FCD Steel / Aluminum / Stainless / Copper / Titanium / Carbide / Mixed chips (aluminum + FC or sintered metal)
Chip shape
Sandy
Grinding chip size
Ultrafine particles (5 μm to 10 μm) / Fine particles (10 μm to 100 μm) / Coarse particles (0.1 mm to 0.5 mm)
Machine tool
Grinding machine / Tool grinding machine / Machining center / NC lathes Induction hardening machine / Cutting specialized machine / Washing machine
You can download a comprehensive catalog that covers Bunri’s products.
https://www.bunri.com/en/download/
Company name | BUNRI Inc. | EMIDAS Member Number | 100081 |
Shinagawa-ku Tokyo Japan |
Telephone number | +81-3-3778-2061 | Fax number | +81-3-3778-2063 |
Employees | 60,000,000 JPY | Annual sales | |
Employees | 160 | Person in charge | Kouhara |
Type of manufacturing | Machine tools / Industrial machinery |
