We solve manufacturing issues. Whether it is improving factory production efficiency or reducing CO2 emissions, Bunri's work is helping to solve problems.
Company name | BUNRI Inc. | Website URL | https://www.bunri.com/en/ |
Street address |
Shinagawa-ku Tokyo Japan
[See map] |
Person in charge | Kouhara |
Telephone number | +81-3-3778-2061 | Fax number | +81-3-3778-2063 |
Capital | 60,000,000 JPY | Employees | 160 |
Annual sales | Unregister | EMIDAS Member Number | 100081 |
Type of manufacturing | Machine tools / Industrial machinery | ||
Main 3 products |
PR message
A manufacturer specializing in coolant filtration equipment that supports Japanese manufacturing and protects the environment
We do work that is kind to people and the earth, taking into consideration everything from the environment at the production site to the global environment.
More than 3,000 companies use Bunri's products in manufacturing.
Bunri's coolant filtration equipment
Various machines found in our daily lives are composed of numerous precision metal parts.
These metal parts are formed by metal processing such as cutting and grinding using machine tools.
During such metal processing, “chips” of various shapes are generated.
In addition, coolant is used to cool, lubricate, clean, and prevent rusting during machining.
Chips and coolant are discharged in a mixed state, and if they are reused as they are, the following problems will occur.
Chips are trapped between the metal and the tool, resulting in less accurate machining and more defective products.
Regular maintenance is required, which reduces the utilization rate of the machine tool.
Shortened tool and coolant life, which has a negative impact on the global environment.
Bunri's “filtration system” solves these problem. The “filtration system” separates “chips” and “coolant”, enabling reuse of coolant and maintaining “good machine tool” condition for a long time.
The value of Bunri 01
Reduction of industrial waste
BUNRI products make it possible to recycle “coolant liquid” and “metal chips.
It is not possible to recycle coolant fluid and swarf if they are mixed together.
The value of Bunri 02
Reduction of CO2 emissions
By introducing Bunri's products, a significant reduction of CO2 emissions can be expected.
BUNRI can contribute to the activities for decarbonization and carbon neutrality that are being promoted around the world.
The Value of Bunri 03
Bunnli's products have been introduced in 30 countries around the world.
Bunri has been delivered to many major companies that have factories overseas, and is used at manufacturing sites around the world.
Our technology is recognized not only in Japan, but around the world.
The Value of Bunri 04
We have delivered our products to more than 3,000 companies.
As the only specialized manufacturer in Japan, we have honed our technology and built trust with our customers.
We will continue to approach environmental issues by delivering the value of Bunri to as many companies as possible.
Most recent update:2025-03-11
